NAT question
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
12-05-2006 03:24 PM - edited 03-03-2019 02:56 PM
I have a 2600 router, with 2 ATM/ADSL dialer interfaces, in production.
I am adding a new ethernet card to the 2600, and will move all upstream traffic from the ADSL lines to a
the new ethernet link.
Currently, NAT is running, with the Dialer interfaces as "Outside" interfaces, and ethernet 0/0 as the inside interface
I will shut down the ATM interfaces, and remove NAT statements from Dialer1 and Dialer 0;
Since I am using a NAT pool with the current dialer interfaces, will I simply move the "ip NAT Outside" to the new ethernet
interface, or will other steps be required ?
interface ATM0/0
interface ATM0/1
interface Ethernet0/0
ip address 172.16.1.1 255.255.0.0
ip nat inside
interface Ethernet 1/0
description New Ethernet upstream link
ip address 192.168.142.9 255.255.255.248
????? ip nat outside
interface Dialer0
no ip nat outside
shutdown
interface Dialer1
no ip nat outside
shutdown
ip nat pool NAT 192.168.132.107 192.168.132.110 netmask 255.255.255.248
ip nat inside source list 1 pool NAT overload
ip nat inside source static 172.16.1.2 192.168.132.105
- Labels:
Other Routing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-05-2006 04:21 PM
the access-list
access-list 1 permit 172.16.0.0 0.0.255.255
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-05-2006 05:17 PM
Yes, move the nat outside command to the correct interface and ensure the nat pool will work w/ new Ethernet address is fine. i.e. confirm the nat pool will not conflict w/ the remote side address ?
Hope this helps.
