NAT syslog logging has increased
mking
We upgraded from 12.2 to 12.4
We have NAT Logging enabled with the following commands.
service timestamps debug datetime localtime show-timezone
service timestamps log datetime localtime show-timezoneip nat log translations syslog
logging queue-limit 100
logging history informational
logging trap debugging
logging x.x.x.x
Under 12.1, our syslog looked like this:
Jan 2 00:02:43 x.x.x.x 16013572: Jan 2 00:02:42 EST: %IPNAT-6-NAT_CREATED: Created ? 10.28.144.81:0 x.x.x.x
:0 0.0.0.0:0 0.0.0.0:0
Jan 2 00:02:46 x.x.x.x 16013573: Jan 2 00:02:45 EST: %IPNAT-6-NAT_DELETED: Deleted ? 10.28.129.55:0 x.x.x.x
(obviously x.x.x.x are real IP's)
One nat would be created per IP, till the timeout cleared it.
Now our logs look like this:
Apr 12 22:44:27 1.1.1.1 125797905: Apr 12 22:44:27 EDT: %IPNAT-6-NAT_CREATED: Created udp 10.16.15.66:39442 x.x.x.162:39442 189.167.131.131:23361 189.167.131.131:23361
Apr 12 22:44:27 1.1.1.1 125797906: Apr 12 22:44:27 EDT: %IPNAT-6-NAT_CREATED: Created udp 10.16.15.66:39442 x.x.x.162:39442 189.152.26.226:45978 189.152.26.226:45978
Several NAT's for the same internal IP, and the same external IP.
Is there a way we can go back to the original logging method? Our logs have gone from several hundred megabytes to 4 or 5 gigs a day, and this is posing a problem.
mking
Nobody has any ideas?
gmarogi
Level 5
Level 5
Upgrade the IOS to 12.4.6(3). It is related to problem bug - CSCek10384
