NAT Translation rule
sameershrestha
Hi All,
We have a small setup with Cisco router, switch and some IP Phones.
I was wondering if we are able to create a NAT rule so that we can access the GUI of the IP phones from the remote network.
Please advise.
Much appreciate your help.
Hello
When you say remote network do you mean -outside your internal network ie: WAN/Internet
You should be able to nat any internal addressing to an outside address range - providing your router supports nat and also you have outside(global) address(es) to use.
Please provide  more detail on the devices involved and we may be able to assist you further.
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
If u are reffering to access ip phones from any remote Public ip location.
Then u can do static nat
nat your Internet ips of phone with public IP.
in that case u will be able to access them globally.
Jawad
Jawad
