NAT with Proxy IP and Port numbers
RAMACHANDRA R
Existing Setup :
Client is getting an internet in ethernet output with private ip ( 10.0.2.5/24 through 10.0.2.8/24 with proxy ip being 10.0.2.90 port 80 ) from their parent company,for accessing the internet the client needs to connect the output to switch and assigning the above given ip,proxy and port number to pc.
requirement:
Can we terminate the smae Ethernet output to the router and make it do nating for the client LAN ( 192.168.10.0/24 )? and client should be able to browse internet without assigning any sort of proxy ip and port number in their pc.
Rama
carenas123
Level 5
Level 5
Dynamic Nating or PAT could be done at the router.The router replaces the sending computer's non-routable IP address with the first available IP address out of the range of unique IP addresses.Refer URL for more info NAT
http://cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094831.shtml#examples
