NAT
Mayur Aher
HI,
I have a Data center at one place & my branch office at other location,
& i have a Public IP at Data Center which i wanted to nat with my branch office PC is it possibel.??
& If its possible then what is the procedure.
Data Center & Branch office is connected through MPLS Link.
Georg Pauwen
make sure all the branch office traffic directed to the Internet is going through the data center. Add the networks of the branch office to the NAT configuration of the data center. That is the theory...
Better if you post the configs of both routers...
Joseph W. Doherty
Generally, yes, it's possible.  Often not too complicated, either.
Generally, your internal network is logically one network topology (i.e. you can route from anywhere to anywhere, again, internally).
Also generally, there's some "one router" which has the "connection" (or next hop path) for Internet traffic.  If non-interior traffic (e.g. Internet bound) gets to this router, it goes to/from Internet too.  The tricky part is how "all" your Internet traffic "knows" to use this "one router".
Sometimes if your main site is small, there's only one "one router" and so other routers, like those at remote sites, don't know to send non-interior traffic to it.
So, for any router that needs to "know" to send to the "one router", generally, either you use a default static route, on all such routers to direct non-local traffic to the "one router" or, if using a routing protocol, you dynamically advertise a default router via your routing protocol.
Once traffic gets to the "one router", again, generally, it doesn't make a difference where that traffic came from within your interior network.  Things like NAT and interior routing should work like they do for just your DC site.
