NBAR Problems
dbellaze
Level 4
Level 4
Hello all.
I have a simple nbar configuration.
Class Map match-any p2p_match
Match protocol kazaa2
Match protocol winmx
Match protocol edonkey
Match protocol gnutella
Match protocol napster
Match protocol fasttrack
Match protocol bittorrent
policy-map p2p_drop
class p2p_match
drop
class class-default
interface gi 0/1.1
service-policy output p2p_drop
The problem I am having is we have some internal applications that traverse this router that happen to use port's that the NBAR signatures have defined.
Does anyone know how to bypass NBAR using source/destination IP's and or ports and still block P2P file sharing with NBAR?
I have been digging around and I can't seem to find a way to do this.
Daniel
d.wingert
Hello Daniel,
how about creating another class-map that filters your internal applications via an access-list on source/destination IPs or ports and to put that class in your policy-map before your class p2p_match?
Something like this:
class-map match-all INTERNAL-APPS
match access-group name ALLOW-INTERNAL-APPS
class-map match-any p2p_match
match protocol kazaa2
match protocol winmx
match protocol edonkey
match protocol gnutella
match protocol napster
match protocol fasttrack
match protocol bittorrent
policy-map p2p_drop
class ALLOW-INTERNAL-APPS
class p2p_match
drop
class class-default
ip access-list extended ALLOW-INTERNAL-APPS
permit ip x.x.x.x 255.255.255.0 x.x.x.x 255.255.255.0
Regards, Dirk.
d.wingert
Hello Daniel,
policy-map p2p_drop
class p2p_match
drop
class class-default
Regards, Dirk.
Actually, I did try that thinking that would be the easiest way. But it didn't work. I didn't even see any hits on the class allowing my internal apps.
I don't know if an action needs to be applied to the class in the policy map for it to take effect?
Daniel
I think you should use nested match classes. This allows you to combine match any and match all. The idea is that the P2P applicaton should be matched, only if the internal ip address are not matched. Consider the following
Class Map match-any p2p_protocol
class-map match-all P2P
Match class-map p2p_protocol
Match not access-group Internal_IP_ACL
policy-map Peer2Peer
class P2P
Dirk,
I tried it again and it worked. Not for sure why it didn't the first time. Maybe I just miss typed some thing.
Daniel
