Need a replacement for a 2821 with AIM\-VPN/EPII\-PLUS encryption module
ckilday
A customer has a 2821 router with an AIM\-VPN/EPII\-PLUS encryption module installed internally. One of the fans failed and I've been tasked with finding an upgraded replacement. Is there a newer model which supports VPN and encryption either through hardware module or software? If so, please send a link or include model/part #'s. Thank you!
Julio E. Moisa
You can find the recommended replacement on this link, once you have selected a router you should verify the model and the type of license.
https://www.cisco.com/c/dam/assets/prod/routers/cisco-router-selector/index.html
For example: the replacement for a 2821 is a Cisco router 4351
And you can find more information on the following link: https://www.cisco.com/c/en/us/products/routers/4000-series-integrated-services-routers-isr/index.html
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Julio E. Moisa
Hope it is useful
chrihussey
Probably a 4000 ISR series router would be a good fit. The 2821s are pretty old and not sure what you need here so check out the different models. They all come with hardware VPN acceleration. I'm not aware of any additional encryption module that needs to be purchased.
https://www.cisco.com/c/en/us/products/routers/4000-series-integrated-services-routers-isr/models-comparison.html
The different models come with a certain perfomance capability and can be upgraded by purchasing a software license.
Hope this helps.
