Need BGP protocol for study
Dear all,
I want to improve my technical skills in BGP protocol, searched serveral times for BGP doucments but couldn't get the docuement however I had gone through cisco docuements ( officials websites ) but there is I get confused while studying BGP protocol  since I'm new for this protocol.
Please guide me where to start to learn it, if is there is any book or pdf please refer to me so that I can strong my technical skills, I want to know where can I get sequence wise chapter from basic to advanced.
Thank you all for your support in advanced.
Umesh Prajapati
there are countless resources on the Internet, not sure what you have found so far, linked below are a few suggestions:
https://archive.nanog.org/sites/default/files/BGP-presentation.pdf
https://www.routeralley.com/guides/bgp.pdf
http://luk.kis.p.lodz.pl/ZTIP/BGP.pdf
Giuseppe Larosa
Hello @Umesh Prajapati11238 ,
Internet Routing Architectures Bassam Halabi second edition 2000
https://www.pearson.com/uk/educators/higher-education-educators/program/Halabi-Internet-Routing-Architectures-2nd-Edition/PGM455652.html?tab=overview
It may be old but it is really valuable. It should provide simple scenarios where it shows the effects of changing the value of a single BGP attribute like Local Preference and so on.
Routing TCP/IP, Volume II (CCIE Professional Development)
By
Jeff Doyle CCIE #1919, Jennifer DeHaven Carroll CCIE #1402
Here you can find the first chapter
Some reference documents
RFC 1771
https://www.rfc-editor.org/rfc/rfc1771.txt
updated document
https://datatracker.ietf.org/doc/html/rfc4271
Support for 4 bytes AS numbers this was quite a big change in BGP
https://datatracker.ietf.org/doc/html/rfc6793
Hope to help
Giuseppe
Martin L
2 good books are 2nd edition Routing TCP/IP, Volume II  By Jeff Doyle, Cisco Press and Internet Routing Architectures, by Bassam Halabi , 2nd second edition, CiscoPress 2000.
Note 2nd edition of book is a bt better; BGP chapters are improved !
You can say always buy /read 2nd second editions
Regards, ML
**Please Rate All Helpful Responses **
