Need Help with Packet Tracer assignment
Vishnu
I have some very terrible configuration with my packet tracer assignment with the vlsm workout I just did can u make sure to see if its right. It was for 210.210.60.0/24
15 Replies 15
Joseph W. Doherty
Could use a tad more info.
here's the info its in the word document with the Tasks I had to complete.
Vishnu
@Joseph W. Doherty did u review the document.
Just saw it now.
Your OP concerns Q3?
If so, "normally" for such exercises, you allocate subnets by size, from largest to smallest.  This insures allocation of address space in the most efficient manner, although, if this was real-world, possibly not in the best manner.
BTW, some of your "sites" with /28 and /30 allocations are curious, as they appear to possibly be single hosts.(?)  Further, you have two entries explicitly labeled "devices" with /28s?
@Joseph W. Doherty so what's the correct TFTP & DHCP Server Network addresses subnet masks & valid addresses?
Servers would normally have hard coded IPs.  Actual IP assignment would depend on what subnet they were placed within.
BTW, unable to open or download the files stored on Google, using just my browser.
@Joseph W. Doherty u can download the zip file here
Ah, that helps much.
Why are you using a /28 on one of your p2p serial links?
BTW, you might also use /31s on your serial links, but using /30s is normally considered fine.
Your TFTF server would use an IP from the 10 hosts Site 3 network.
Your DHCP server is on it's own, dedicated, router interface. For that, provide it its own /30.
BTW, your static routing statements appear to not support your WAN redundancy.
@Joseph W. Doherty I just updated it as I was able to add the static routes & able to backup the running-config files to the TFTP server, but however, I wasn't able to ping to all networks can u please correct my static routes for each one according to the VLSM scheme as my practical assignment is due on the 25th of May at 11:59pm AEST.
@Joseph W. Doherty I need to ping to all networks in this topology using the graphic simulation.
ALL networks, or just edge/host networks?
Static routing:  you have multiple WAN paths, so you some choices choosing a single path.  You can also do ECMP, although in some failure situations you'll drop half your traffic.  With SLA, you could deal with the aforementioned potential ECMP issue, you could also set up backup paths.   I doubt PT supports SLA with static routing.
Dynamic routing:  even with just this topology, a better option.  Since you're subnetting a Class C, RIP is ruled out, but RIPv2, OSPF or EIGRP would be fine (I know PT runs OSPF).
Your existing static routes show you appear to understand what you need, but I haven't verified all of them.  Do have a specific routing question or issue?
just fixed it now.
M02@rt37
Hello @Vishnu
Your Q3 task 3 seem to be good
Sites
Network address
Subnet Mask
Valid Addresses
Site 1 (60 hosts)
210.210.60.0/26
255.255.255.192
210.210.60.1 -210.210.60.62
Site 2 (20 hosts)
210.210.60.64/27
255.255.255.224
210.210.60.65 -210.210.60.94
Site 3 (10 hosts)
210.210.60.96/28
255.255.255.240
210.210.60.97 – 210.210.60.110
ChatGPT - Bard
210.210.60.112/28
255.255.255.240
210.210.60.113 – 210.210.60.126
Bard - Deepblue
210.210.60.128/30
255.255.255.252
210.210.60.129 – 210.210.60.130
Deepblue – Watson
210.210.60.132/30
255.255.255.252
210.210.60.133 – 210.210.60.134
ChatGPT - Watson
210.210.60.136/30
255.255.255.252
210.210.60.137 – 210.210.60.138
Devices
IP Address
Subnet Mask
Valid Addresses
TFTP server
210.210.60.144/28
255.255.255.240
210.210.60.145 – 210.210.60.158
DHCP Server
210.210.60.144/28
255.255.255.240
Same subnet for TFTP and DHCP server ?
Best regards
M02@rt37 what about Q4 Task 4 & Q5 Task 5 does that seem okay, & for the end devices & router ip configurations with the DHCP, TFTP Site 3 PC-PT 10 hosts, PC0, PC1 & Site 2 PC-PT 20 hosts, Site 1 PC-PT 60 hosts, + Chat GPT, Bard, Deepblue, Watson does that seem okay aswell. aswell as Task 6 with the static routes I added as its in the zip file here:
