10-22-2011 01:17 PM - edited 03-04-2019 02:01 PM
10.205.248.25 is dropping pings and when I checked the routes to the address from L3 switch and the router it keeps getting advertised by BGP and OSPF alternatively..What should I be doing?
Router#sh ip route 10.205.248.25
Routing entry for 10.205.248.24/30
Known via "bgp 64512", distance 200, metric 15101, type internal
Redistributing via ospf 10
Last update from 10.223.255.203 00:00:00 ago
Routing Descriptor Blocks:
* 10.223.255.203, from 10.223.255.203, 00:00:00 ago
Route metric is 15101, traffic share count is 1
AS Hops 0
Known via "bgp 64512", distance 20, metric 0
Tag 64514, type external
Advertised by ospf 10 metric 15000 metric-type 1 subnets tag 64512 route-map BGP_TO_OSPF
Last update from 10.255.249.2 00:00:00 ago
* 10.255.249.2, from 10.255.249.2, 00:00:00 ago
Route metric is 0, traffic share count is 1
AS Hops 5
Route tag 64514
10-22-2011 02:21 PM
Looks like a classic case of recursive routing. Post the config of the device for which the /30 is being advertised.
10-22-2011 03:13 PM
interface Loopback0
description loopback interface for RICRALAJU-VPN-B
ip address 10.205.255.30 255.255.255.255
interface Tunnel1
description TUNNEL to RDCATEMECU-VPN-A Tunnel 3
bandwidth 4000
ip address 10.205.248.25 255.255.255.252
ip access-group BLOCK-IPVIDEO-VOICE in
no ip redirects
no ip proxy-arp
ip flow ingress
ip flow egress
no snmp ifindex persist
qos pre-classify
keepalive 10 3
tunnel source 201.204.115.34
tunnel destination 130.36.3.249
service-policy output QOS-GLOBAL-4M
interface Null0
no ip unreachables
interface GigabitEthernet0/0
description INTERNAL interface for RICRALAJU-VPN-B
ip address 10.197.57.250 255.255.255.0
ip helper-address 10.215.239.95
ip helper-address 10.229.248.50
no ip redirects
no ip proxy-arp
duplex auto
speed 100
no cdp enable
service-policy input QOS-CLEAR-DSCP
interface GigabitEthernet0/1
description EXTERNAL 4M ICE Circuit ID 1737-5880
bandwidth 4000
ip address 201.204.115.34 255.255.255.252
ip access-group OUTSIDE_INT in
no ip redirects
no ip unreachables
no ip proxy-arp
duplex full
speed 100
no cdp enable
crypto map abbott-map
max-reserved-bandwidth 80
interface Async0/3/0
description Need Phone Number
no ip address
encapsulation slip
router bgp 64626
no synchronization
bgp router-id 10.205.255.30
bgp log-neighbor-changes
network 10.197.57.0 mask 255.255.255.0
network 10.205.248.24 mask 255.255.255.252
network 10.205.255.30 mask 255.255.255.255
timers bgp 20 60
neighbor 10.205.248.26 remote-as 64514
neighbor 10.205.248.26 description eBGP peer to RDCATEMECU-VPN-A Tunnel3
no auto-summary
10-25-2011 10:57 AM
The config is not the device that is sending the route...
So have a look @ 10.255.249.2 and you might find either an incorrect ACL or Prefix list that contains the /30 in the redistribution.
HTH>
