Need someone to check ASA 5505 port forwarding config
Reprovoid
Hi.I've configured port forwarding on an ASA 5505 to connect to an Access Point web administration.This Is for testing purposes only.
  I've followed the guidelines for port forwarding and I've created an access list but I can't connect to the AP.I know It's working because It connects fine when connected to my speedtouch router.
I've attached a running-config.Any assistance would be appreciated! Thanks
I'm getting hit counts on the ACL and I'm getting untranslate_hits on the nat but no translate hits.
interface Vlan1
nameif inside
security-level 100
ip address 10.0.0.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 192.168.10.16 255.255.255.0
access-list switchsdm extended permit tcp any any eq www
global (outside) 1 interface
nat (inside) 1 10.0.0.0 255.255.255.0
static (inside,outside) tcp interface www 10.0.0.2 www netmask 255.255.255.255
access-group switchsdm in interface outside
route outside 0.0.0.0 0.0.0.0 192.168.10.254 1
Reprovoid
Pleas Sirs, Madams I require your expertise! I Implore you're kindness as a humble network understudy and what have you!!
Ok. Note to self.
  Do not use cheap tp-link access point to test port forwarding.
  Do not try and remote desktop to a windows 7 starter machine.
It was working all along!
