Need T1 help (basic stuff)
jwhaas052671
I know the commands, just not always the proper way to put it in. A company I work for is getting off of DSL and moving to a T1. Their IP addresses are going to change as well. I need pointed in the right direction on how to setup their cisco (which has a built in CSU/DSU) to point to their ISP. The company is just one building then out to the ISP. It's going to be a couple weeks out, so I have time to research it. I don't have the range yet. They also have a PIX 5505, but I have the configuration copied of for that. The cisco config will be all new. I know it's a full T1 and frame relay will be setup. Just need a little sample config to jar my mind back into it. I know it's simple, just lost my mind I guess.
Reza Sharifi
Here is sample config for your T1 interface
This example assumes your interface is 0/0 and the DLCI of 100.
interface Serial0/0:0
no ip address
encapsulation frame-relay
interface Serial0/0:0.1 point-to-point
ip address 172.16.1.1 255.255.255.252
frame-relay interface-dlci 100
Thank you very much. I have a case of the stupids for some reason as this is pretty easy stuff and it's like it all left me. I'll run this in my sim and inquire about the companies new scheme. Maybe it will come back.
Rick Morris
Level 6
Level 6
You said internal CSU so I assume you are referring to a controller interface.
Don't forget you will need to configure that too.
controller T1 0/0
framing  esf
clock source line      (typically you are pulling clocking from the network so make sure you ask the ISP about this to make sure they are providing)
linecode b8zs
channel-group  0 timeslots 1-24
no ip address
ip  address 1.1.1.1 255.255.255.252
Rick,
All new WICs come with build in CSU/DSU.  In the old days, there was an external CSU/DSU, but not any more.
Also, the controller config you provided is for T1/PR1 interface not for a regular T1.
