03-09-2010 11:26 AM - edited 03-04-2019 07:45 AM
H i ...
I have configured PFR between hub & spoke site , applicaiton server is at hub location & client is on spoke site .
both sites have one MC/BR and one BR router . How can i verify pfr is working fine .show command outputs for MC and BR attached for ref .
thnx
madu
Solved! Go to Solution.
12-08-2010 07:45 PM
We have a PfR troubleshooting document which I would recommend for review:
http://docwiki.cisco.com/wiki/PfR:Troublehooting:System
Once you have verified the operation of the PfR system then you can issue the following commands:
show oer master policy - provides information on your configured policy settings.
show pfr master policy - same command however in newer code it was changed to keyword pfr.
show oer master prefix - provides information on prefixes that have been learned.
show pfr master prefix - same command however in newer code it was changed to the keyword pfr.
If you have any further questions please let me know.
Best Regards,
Steve Lyons - Cisco
12-08-2010 07:45 PM
Best Regards,
Steve Lyons - Cisco
