05-02-2012 08:50 AM - edited 03-04-2019 04:14 PM
Hi Experts
BGP issue
neighbor Y.Y.Y.Y shutdown , how to bring it back ? neighbor Y.Y.Y.Y activate doesn't work?
ios xe on asr 1000
thanks
jamil
05-02-2012 09:02 AM
"no neighbor Y.Y.Y.Y shutdown" should work,
05-02-2012 09:46 AM
To disable a neighbor or peer group, use the neighbor shutdown command in router configuration mode. To reenable the neighbor or peer group, use the no form of this command.
neighbor {ip-address | peer-group-name} shutdown
no neighbor {ip-address | peer-group-name} shutdown
Posted by WebUser Neeraj Jagga from Cisco Support Community App
05-02-2012 10:03 AM
Jamil,
As others have said, you can do a "no
John
