Network Advertisement
massimo.disanto
Hello to All
on CE Router XXX I have below network
XXX#sh ip route 172.16.100.1
Routing entry for 172.16.100.1/32
  Known via "bgp 11111", distance 20, metric 0
  Tag 13879, type external
  Redistributing via eigrp 100
  Advertised by eigrp 100 metric 300000 1 255 1 1500
  Last update from AA.BBB.CCC.DD 1w1d ago
  Routing Descriptor Blocks:
  * AA.BBB.CCC.DD, from AA.BBB.CCC.DD, 1w1d ago
      Route metric is 0, traffic share count is 1
      AS Hops 2
      Route tag 13879
      MPLS label: none
It is being advertised by PE router YYY, could someone provide me with correct command I can do on PE YYY in order to know details about destination 172.16.100.1?
Thanks/regards
Massimo
Mark Malone
HI
On the PE side router you would could check that route with command like below but you need to know the vrf
show ip bgp vpnv4 vrf mark 172.16.100.1
Mark Malone
HI
