Network Engineer
Mark Allen
On the ASR1001 I am unable to change the speed and duplex on a gig port when the sfp is a multimode fiber(sx) , need to change to 100 full,should the sfp on the ASR1001 be able to be set to 100 full.
5 Replies 5
Leo Laohoo
You can't and you won't.
Cisco SFP can only support one speed.
100BaseFx SFP has the part number of GLC-GE-100FX.
I read on cisco website that the  GLC-GE-100FX will only work on 5 port and 6 port spa...is that correct?
my 1002-f has a 4 port spa....
cisco ASR1002-F (2RU) processor with 1700144K/6147K bytes of memory.
4 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
7798783K bytes of eUSB flash at bootflash:.
ASB-DC-WAN-RT01>sh inventory
NAME: "Chassis", DESCR: "Cisco ASR1002 Fixed Chassis"
PID: ASR1002-F         , VID: V03, SN: FOX1516G6PW
NAME: "Power Supply Module 0", DESCR: "Cisco ASR1002 AC Power Supply"
PID: ASR1002-PWR-AC    , VID: V02, SN: ART1546U04X
NAME: "Power Supply Module 1", DESCR: "Cisco ASR1002 AC Power Supply"
PID: ASR1002-PWR-AC    , VID: V02, SN: ART1544U0E0
NAME: "module 0", DESCR: "Cisco ASR1002-F SPA Interface Processor 10"
PID: ASR1002-SIP10-F   , VID: V03, SN: JAE15480CHZ
NAME: "SPA subslot 0/0", DESCR: "4-port Gigabit Ethernet Shared Port Adapter"
PID: 4XGE-BUILT-IN     , VID: V00, SN: N/A
NAME: "subslot 0/0 transceiver 0", DESCR: "GE T"
PID: N/A                 , VID: E   , SN: MTC154902UU
NAME: "subslot 0/0 transceiver 1", DESCR: "GE T"
PID: N/A                 , VID: E   , SN: MTC1549024N
NAME: "subslot 0/0 transceiver 3", DESCR: "GE SX"
PID: GLC-SX-MMD          , VID: 001 , SN: AGA1732R96U
NAME: "module R0", DESCR: "Cisco ASR1002 Route Processor 1"
PID: ASR1002-RP1       , VID: V03, SN: JAE15480EGT
NAME: "module F0", DESCR: "Cisco ASR1000 Embedded Services Processor, 2.5Gbps"
PID: ASR1002-ESP-F     , VID: V03, SN: JAE15480847
Incorrect.  I believe only in the 5- or 10 port SPA.
Cisco 2-, 5-, 8-, and 10-Port Gigabit Ethernet Shared Port Adapters, Version 2
Hi Leo
I have an issue in my data center, could you please me help out.
I have Cisco ASR1006 router in my data center and a 100Mpbs WAN link (over OFC) is coming from my ISP to my premises. The issue is my ISP is having 100BaseFx module at its end and I am having 1000BaseFx modules in my router. How should I terminate the OFC on my router as 100BaseFx are 1000BaseFx are incompatible ? Please recommend any SFP which I could use at my end in order to terminate the OFC directly on my router.
I have already responded to your THREAD and the answer to your question can be found in this thread.
