network install test plan
aaronkb2002
HI !
Can anyone help with a test plan that I can use after a install of network hardware ?
Or point me in the right direction ?
Apprreciate the help
thank you
Aaron
Hello.
Typically if you change running network the test plan would be to check is provided service is up and running after the change (and compare respective outputs with baseline).
If you deploy a new network, than the project itself should provide you a list of delivers you are expecting.
So, the test plan comes from the change itself.
