New 4331 very slow and intermittent internet
Jkad432
Hello all,
 replaced a 2900 router with a new 4331 isr. Worked great for 5 days and then Became increasingly unresponsive. Reset to factory and started from scratch again and it works (local network works great) seeing some packet loss pinging external ip from an external network and it’s very slow loading web pages, I currently have the trial boost license. I have gotten the notice that I was approaching the license cap one time. Negotiation is set to auto.
any ideas what would be causing such slow speeds
18 Replies 18
Jkad432
sh license
Index 1 Feature: appxk9
        Period left: Not Activated
        Period Used: 0  minute  0  second
        License Type: EvalRightToUse
        License State: Active, Not in Use, EULA not accepted
        License Count: Non-Counted
        License Priority: None
Index 2 Feature: uck9
Index 3 Feature: securityk9
Index 4 Feature: ipbasek9
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Priority: Medium
Index 5 Feature: FoundationSuiteK9
Index 6 Feature: AdvUCSuiteK9
Index 7 Feature: cme-srst
        License Count: 0/0  (In-use/Violation)
Index 8 Feature: hseck9
Index 9 Feature: throughput
        Period left: 7  weeks 4  days
        Period Used: 6  days 19 hours
        License Priority: Low
Index 10 Feature: internal_service
Jkad432
should i upgrade the ios xe software?
Jkad432
Here is my LAN sh inter
GigabitEthernet0/0/1 is up, line protocol is up
  Hardware is ISR4331-3x1GE, address is 3c13.cccc.c351 (bia 3c13.cccc.c351)
  Internet address is X.X.X.X/23
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 2/255, rxload 65/255
  Keepalive not supported
  Full Duplex, 1000Mbps, link type is auto, media type is RJ45
  output flow-control is off, input flow-control is off
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 57305
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 257319000 bits/sec, 31292 packets/sec
  5 minute output rate 8508000 bits/sec, 11136 packets/sec
     1849991537 packets input, 1883417327760 bytes, 0 no buffer
     Received 80916 broadcasts (0 IP multicasts)
     40802 runts, 0 giants, 0 throttles
     646549 input errors, 646549 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 73977 multicast, 0 pause input
     648020027 packets output, 101963949439 bytes, 0 underruns
     0 output errors, 0 collisions, 5 interface resets
     1620 unknown protocol drops
     5 lost carrier, 0 no carrier, 0 pause output
Leo Laohoo
Potential speed/duplex mismatch error.
This is a copper port.  The port configuration should be auto speed/auto duplex.
