New 4431 upload speeds about 10% of norm.
swicklund
Replaced old EOS/EOL router with a 4431 with a 100Mbps synchronous connection.  Internet speeds were about 5mbps.  I fixed download speeds by replacing duplex/speed commands with negotiate auto on both ends.  However the issue remains with upload speeds.  The config is below, any help is appreciated.
no aaa new-model
clock timezone CST -6 0
clock summer-time CDT recurring
no ip domain lookup
ip domain name unity.org
subscriber templating
vpdn enable
password encryption aes
license udi pid ISR4431/K9 sn FOC22055TF0
username xxxxxxx privilege 15 password xxxxxxxxxxxxxxxx
redundancy
mode none
vlan internal allocation policy ascending
ip tcp path-mtu-discovery
class-map match-all MATCHtoReduce
match access-group 199
policy-map OUTTOATT
class class-default
shape average 100000000
policy-map KnockItDown
class MATCHtoReduce
shape average 97000000
interface Multilink1
no ip address
ppp multilink
ppp multilink group 1
interface GigabitEthernet0/0/0
description at&t Circuit ID AT&T Circuit ID: BBEC544157 ATI - LEC CKT ID: 82KQGN702206SW
ip address 12.247.xxx.xxx 255.255.255.252
negotiation auto
service-policy output KnockItDown
ip virtual-reassembly max-reassemblies 64
interface GigabitEthernet0/0/1
no ip address
negotiation auto
interface GigabitEthernet0/0/1.901
encapsulation dot1Q 901
ip address 66.143.36.2 255.255.255.0
ip access-group 110 in
interface GigabitEthernet0/0/1.998
encapsulation dot1Q 998
ip address 68.171.xx.xx 255.255.255.224
interface GigabitEthernet0/0/2
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/3
no ip address
shutdown
negotiation auto
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
interface Virtual-Template1
ip unnumbered Multilink1
peer default ip address pool SDM_POOL_1
no keepalive
ppp encrypt mppe auto
ppp authentication pap chap ms-chap
interface Vlan1
no ip address
shutdown
interface Group-Async0
physical-layer async
no ip address
encapsulation slip
no group-range
router bgp 27332
bgp log-neighbor-changes
network 66.143.36.0 mask 255.255.255.0
neighbor 12.119.234.137 remote-as 7018
neighbor 12.247.185.113 remote-as 7018
ip local pool SDM_POOL_1 10.253.251.1 10.253.251.253
ip nat inside source route-map SendToLupo interface GigabitEthernet0/0/0 overload
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route xx.xx.xx.xx 255.255.255.255 66.143.36.1
ip route 68.143.xx.xx 255.255.255.248 GigabitEthernet0/0/1
ip route 209.248.xxx.xxx 255.255.255.248 GigabitEthernet0/0/1
ip ssh version 2
ip prefix-list 17279-in description Accept default route from KBI only
ip prefix-list 17279-in seq 10 permit 0.0.0.0/0
ip prefix-list my-block description My subnets to announce out
ip prefix-list my-block seq 10 permit 66.143.36.0/24
access-list 198 permit ip host 68.143.xx.xx any
access-list 199 permit ip any any
route-map SendToLupo permit 10
match ip address 198
route-map ReDirect_TheNATed_Folks permit 10
set ip next-hop 67.64.xx.xx
route-map nonat permit 10
match ip address 103
snmp-server community unity_snmp RW
snmp-server location Unity Village, MO
snmp-server contact Unity Village IT Dept.
snmp-server enable traps tty
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
banner motd alias interface g0/1 internal
alias interface multilink1 external
@swicklund wrote:
Half Duplex, 100Mbps, link type is auto, media type is RJ45
"Half Duplex"?
@swicklund wrote:
0 output errors, 308329 collisions, 1 interface resets
And there's your allowed bandwidth goooooone right there.
Talk to AT&T and ask them if they've hard-coded speed and duplex on their side.  (Be prepared for AT&T to deny anything-and-everything.)
Leo Laohoo
Post the complete output to the command "sh interface Gi 0/0/0".
UNITY-4431#sh int gi 0/0/0
GigabitEthernet0/0/0 is up, line protocol is up
Hardware is ISR4431-X-4x1GE, address is 28ac.9ee0.69c0 (bia 28ac.9ee0.69c0)
Description: at&t Circuit ID AT&T Circuit ID: BBEC544157 ATI - LEC CKT ID: 82KQGN702206SW
Internet address is 12.247.185.114/30
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
reliability 255/255, txload 13/255, rxload 11/255
Keepalive not supported
output flow-control is off, input flow-control is off
Last input 00:03:22, output 00:00:26, output hang never
Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 12151
Queueing strategy: Class-based queueing
Output queue: 0/40 (size/max)
5 minute input rate 4511000 bits/sec, 1053 packets/sec
5 minute output rate 5399000 bits/sec, 890 packets/sec
17047344 packets input, 8255868944 bytes, 0 no buffer
Received 14 broadcasts (0 IP multicasts)
0 watchdog, 0 multicast, 0 pause input
15469141 packets output, 12751100741 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
UNITY-4431#
"Half Duplex"?
I saw the half-duplex but missed the collisions.  ATT "resolved" my ticket but did not note it in any way.  I talked with my boss and just went ahead and set the port to full duplex, speed 100 and that fixed it.
