11-18-2010 07:59 AM - edited 03-04-2019 10:30 AM
Hi all,
I am using 1812 Router and with 32M CF Card and 4G CF Card too with 384MB RAM. I setting it work well on IOS advipservicesk 124-15.T12 by SDM and just basic Firewall etc ....
But when I not change any setting and using the IOS advipservicesk9-mz.124-24.T, plus other 124-20 or above IOS
After reload the router by any advipservicesk9-mz.124-20 or above IOS My Router will out of work.
It FE0/2 interface on the configuration is 10.10.10.1/29 with Vlan1
But I can ping my workstation 10.10.10.2 on the same LAN and also the the FE0/0 DHCP then connect to my ISP Router also not work anymore.
But if I change back to the advipservices 124-15.T12 IOS and reload, the Router will all thing come up again like my WAN, LAN all can using no problems....
Why the other IOS image make the problems like that?
Thank you very much and wish you have a nice day.
11-20-2010 04:50 AM
After run the "erase startup-config" command and reload... the 12.4(20) above image work
I can ping www.yahoo.com on the console.
But all old setting are lost I need setting the 1812. But this time the Cisco SDM not come to work again.
Do any one can teach me how to setting the 1812 can online to access both WAN (Internet) and LAN
Here are my environment.
ISP give me IP by DHCP.
And I using 1812's FA0/0 as WAN interface, and no change anything, it can handle the IP by DHCP auto ....
FA0/1 is not setting anything like it default
FA0/2 connect to my workstation (1812's Switch Port) but VLAN1 is not setting like default ...
I am using other computer to post here since now the 1812 come back to default ... and the problems is it can't open the SDM again. Only can access by console and CLI
Here are my running-config
Building configuration...
Current configuration : 1052 bytes
version 12.4
hostname hostname
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
username james privilege 15 secret 5 $1$ek2x$IwRw1DBMrSLJaLxY6oMCm0
archive
log config
hidekeys
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet0
ip address dhcp
duplex auto
speed auto
interface FastEthernet1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Vlan1
no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
Thank you very much of your time and answer.
11-25-2010 06:08 AM
Hi all,
After do some CCNA book research, I can using the 12.424T3 IOS and make the router online and post here as basic function.
A small step to the CCNA world
Here are my setting.
Current configuration : 1254 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
username jimmy privilege 15 secret 5 $1$ek2x$IwRw1DBMrSLJaLxY6oMCm0
archive
log config
hidekeys
interface BRI0
no ip address
encapsulation hdlc
shutdown
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
ip address 10.10.10.1 255.255.255.248
ip nat inside
no ip http server
ip nat inside source list 1 interface FastEthernet0 overload
access-list 1 permit 10.10.10.0 0.0.0.7
control-plane
line con 0
line aux 0
line vty 0 4
login
end
Router#
11-25-2010 06:18 AM
So what do you want to know now?
Regards.
