Newbie issues with layer 3 on SG250-08 switch.
admin28373
I would be grateful if I could be pointed in the right direction.
I have Vlans configured. Is it possible to route between PC(Vlan1) and pc(Vlan20) but only based on their ip address or macid?
I dont want all devices in both vlans to be accessible to each other.
2 Accepted Solutions
Thank you for acl info. How do I enable inter lan routing?
based on the information you posted originally assuming that your Layer3 working now you want to block IP to IP communication by putting ACL,
If this is not the case, then you need to enable Layer 3 feature in the SG switch
https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-small-business-300-series-managed-switches/smb5073-switching-to-layer-3-mode-on-the-sf-sg-300-series-switches.html
BB
since you apparently have access to the command line, just configure 'ip routing' in global config mode (page 405 of the attached CLI command reference):
--> To enable IP routing, use the ip routing command in global configuration mode. To disable IP routing, use the no form of this command.
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/250_/2_4_5/cli_guide/cli_sx250_2_4_5.pdf
BB
