297
Beginner
Nexus 9K EVPN VXLAN using EBGP as the Underlay
Hi- I am having as issue with the spine receiving type-2 routes. The type-2 route for a connected host is present on the Leaf, but not advertised up to spine. Any help is appreciated.
!-Leaf nve output
VTEP01# show nve interface
Interface: nve1, State: Up, encapsulation: VXLAN
VPC Capability: VPC-VIP-Only [notified]
Local Router MAC: 5000.0007.0007
Host Learning Mode: Control-Plane
Source-Interface: loopback1 (primary: 10.1.2.3, secondary: 10.1.3.3)
!-end
!-Leaf type-2 entry for attached host
VTEP01# show bgp l2vpn evpn route-type 2
BGP routing table information for VRF default, address family L2VPN EVPN
Route Distinguisher: 10.1.1.3:33768 (L2VNI 2001001)
BGP routing table entry for [2]:[0]:[0]:[48]:[0050.7966.6809]:[0]:[0.0.0.0]/216, version 17
Paths: (1 available, best #0)
Flags: (0x000102) (high32 00000000) on xmit-list, is not in l2rib/evpn, is not in HW
Path type: local, path is invalid(rnh not resolved), no labeled nexthop
AS-Path: NONE, path locally originated
10.1.3.3 (inaccessible, metric 4294967295) from 0.0.0.0 (10.1.1.3)
Origin IGP, MED not set, localpref 100, weight 32768
Received label 2001001
Extcommunity: RT:65001:2001001 SOO:10.1.3.3:0 ENCAP:8
BGP routing table entry for [2]:[0]:[0]:[48]:[0050.7966.6809]:[32]:[4.1.1.10]/248, version 10
Received label 2001001 900001
Extcommunity: RT:65001:101 RT:65001:2001001 SOO:10.1.3.3:0 ENCAP:8
Router MAC:5000.0007.0007
!-end
!-begin spine config
hostname SPINE-1
nv overlay evpn
feature bgp
feature pim
ip pim rp-address 100.1.1.1 group-list 224.0.0.0/4
ip pim ssm range 232.0.0.0/8
ip pim anycast-rp 100.1.1.1 10.1.1.1
ip pim anycast-rp 100.1.1.1 10.1.1.2
vlan 1
ip prefix-list LOOP seq 10 permit 10.1.1.1/32
ip prefix-list LOOP seq 20 permit 100.1.1.1/32
route-map DIRECT-ROUTES-MAP permit 10
match ip address prefix-list LOOP
route-map UNCHANGED permit 10
set ip next-hop unchanged
interface Ethernet1/1
no switchport
ip address 10.0.0.0/31
ip pim sparse-mode
no shutdown
interface Ethernet1/2
no switchport
ip address 10.0.0.2/31
ip pim sparse-mode
no shutdown
interface Ethernet1/3
no switchport
ip address 10.0.0.4/31
ip pim sparse-mode
no shutdown
interface Ethernet1/4
no switchport
ip address 10.0.0.6/31
ip pim sparse-mode
no shutdown
interface loopback0
ip address 10.1.1.1/32
interface loopback1
description ANYCAST-RP
ip address 100.1.1.1/32
router bgp 65000
router-id 10.1.1.1
address-family ipv4 unicast
redistribute direct route-map DIRECT-ROUTES-MAP
maximum-paths 2
address-family l2vpn evpn
nexthop route-map UNCHANGED
retain route-target all
neighbor 10.0.0.1
remote-as 65001
allowas-in 3
disable-peer-as-check
send-community
send-community extended
neighbor 10.1.1.3
remote-as 65001
update-source loopback0
ebgp-multihop 3
send-community
route-map UNCHANGED out
!-end spine
!-begin leaf
nv overlay evpn
feature bgp
feature pim
feature fabric forwarding
feature interface-vlan
feature vn-segment-vlan-based
feature lacp
feature vpc
feature nv overlay
fabric forwarding anycast-gateway-mac 0000.2222.3333
vlan 101
vn-segment 900001
vlan 1001
vn-segment 2001001
vlan 1002
vn-segment 2001002
vlan 3965
name vpcPeerIbgp
vlan 3966
name vpcKeepAlive
vlan 3967
name vpcPeerLink
ip prefix-list LOOP seq 10 permit 10.1.1.3/32
ip prefix-list LOOP seq 20 permit 10.1.2.3/32
match ip address prefix-list LOOP-ZERO
route-map SET-PEER-AS-NEXTHOP permit 10
set ip next-hop peer-address
vrf context keepalive
vrf context vxlan-900001
vni 900001
rd auto
route-target import 65001:101
route-target import 65001:101 evpn
route-target export 65001:101
route-target export 65001:101 evpn
address-family ipv6 unicast
vpc domain 1
role priority 1
system-priority 4000
peer-keepalive destination 192.168.0.2 source 192.168.0.1 vrf keepalive
peer-gateway
layer3 peer-router
interface Vlan101
no shutdown
vrf member vxlan-900001
ip forward
interface Vlan1001
no shutdown
ip address 4.1.1.1/24
ipv6 address 4:1:0:1::1/64
fabric forwarding mode anycast-gateway
interface Vlan1002
no shutdown
ip address 4.2.2.1/24
ipv6 address 4:2:0:1::1/64
interface Vlan3965
no shutdown
no ip redirects
ip address 192.168.1.1/30
no ipv6 redirects
interface Vlan3966
no shutdown
vrf member keepalive
no ip redirects
ip address 192.168.0.1/30
no ipv6 redirects
interface port-channel1
description vpc peer link
switchport mode trunk
switchport trunk allowed vlan 3965,3967
spanning-tree port type network
vpc peer-link
interface nve1
no shutdown
host-reachability protocol bgp
source-interface loopback1
member vni 900001 associate-vrf
member vni 2001001
mcast-group 239.0.0.1
member vni 2001002
no switchport
ip address 10.0.0.1/31
ip pim sparse-mode
no shutdown
switchport access vlan 1001
interface Ethernet1/6
switchport access vlan 3966
interface Ethernet1/7
channel-group 1 mode active
interface Ethernet1/8
interface loopback0
ip address 10.1.1.3/32
ip pim sparse-mode
interface loopback1
ip address 10.1.2.3/32
ip address 10.1.3.3/32 secondary
ip pim sparse-mode
router bgp 65001
router-id 10.1.1.3
maximum-paths 2
neighbor 10.0.0.0
remote-as 65000
allowas-in 3
send-community
neighbor 10.1.1.1
remote-as 65000
ebgp-multihop 3
allowas-in 3
send-community
vrf vxlan-900001
evpn
vni 30000 l2
rd auto
route-target import auto
route-target export auto
vni 2001001 l2
rd auto
vni 2001002 l2
rd auto
!-end Leaf
Everyone's tags (5)
3 REPLIES 3
VIP Mentor
Re: Nexus 9K EVPN VXLAN using EBGP as the Underlay
at first glance, you are missing 'ip pim sparse-mode' on the loopbacks of your spine:
interface loopback0
--> ip pim sparse-mode
interface loopback1
Your prefix list on the LEAF is wrong (or match statement in the route-map)
Hall of Fame Expert
Hello desert7791,
I agree with Alexej
see the following section of first show output
on the other leaf node you are not advertising the loop1 secondary address 10.1.3.3 in AF IPv4 unicast that should be your underlay.
The prefix-list LOOP needs to allow also 10.1.3.3/32 and must be called in the route-map named DIRECT-ROUTES-MAP
or you can simply use
network 10.1.3.3 255.255.255.255
in router bgp address family ipv4 unicast config mode
Hope to help
Giuseppe
Content for Community-Ad
July's Community Spotlight Awards
