Nexus EIGRP route filtering.
sushil968
Hi Friends,
Current Config.
prefix-list DC_ROUTE_110 seq 1 deny 0.0.0.0/0
prefix-list DC_ROUTE_110 seq 2 permit 0.0.0.0/0 Ie 32
route-map DC_ROUTE permit 10
match ip address prefix-list DC_ROUTE_110
router eigrp 110
default-information originate
redistribute eigrp 1 route-map DC_ROUTE_110
router eigrp 1
redistribute eigrp 110 route-map DC_ROUTE
So following is my observation after implementation.
EIGRP 1 is running with service provider and EIGRP 110 is running within my DC. With above configuration, on EIGRP 110 " redistribute eigrp 1 route-map DC_ROUTE_110" , this is preventing any default route being to get redistribute on EIGRP-110. But I am having chllange as am still learning default route 0.0.0.0/0 from service provider on EIGRP-1 which I dont want at all. How can I prevent my network from learning default route from service provider on EIGRP-1 ? Is there any other mechanism to filter default route being learned from Service Provider ? I also want to filter 192.168.0.0/16 route being learned from service provider on EIGRP-1.
Jon Marshall
Sushil
You need to use a distribute list to filter those routes so you need to define your prefix list as before -
ip prefix-list deny 0.0.0.0/0
ip prefix-list deny 192.168.0.0/16
ip prefix-list permit 0.0.0.0/0 le 32
note you only need the last line if you are receiving other routes from the SP that you want.
Then you need to apply it to the interface connecting to the SP on which you are running EIGRP.
The syntax of the command for this on the Nexus is -
ip distribute-list eigrp prefix-list in
where is the AS you are  filitering routes in.
Jon
