NHRP issue
Hi all,
I have problem when I doing DMVPN lab.
I configure the hub and spoke router.
The spoke router is working. Use "sh dmvpn" can see output and can send NHRP Registration request to hub router.
But "sh dmvpn" and "sh ip nhrp" show nothing on the hub router.
the hub router config is:
interface Tunnel0
 ip address 172.16.123.3 255.255.255.0
 no ip redirects
 ip nhrp map multicast dynamic
 ip nhrp network-id 10
 tunnel source GigabitEthernet0/1
 tunnel mode gre multipoint
the spoke router config is:
interface Tunnel0
ip address 172.16.123.1 255.255.255.0
ip nhrp map 172.16.123.3 10.100.100.2
ip nhrp map multicast 10.100.100.2
ip nhrp nhs 172.16.123.3
tunnel source GigabitEthernet0/2
tunnel destination 10.100.100.2
the hub router show:
Hub#show dmvpn
Legend: Attrb --> S - Static, D - Dynamic, I - Incomplete
N - NATed, L - Local, X - No Socket
T1 - Route Installed, T2 - Nexthop-override
C - CTS Capable
# Ent --> Number of NHRP entries with same NBMA peer
NHS Status: E --> Expecting Replies, R --> Responding, W --> Waiting
UpDn Time --> Up or Down Time for a Tunnel
I check the connectivity between spoke and hub is work.
How can I solve it?  Thank you.
Hi all,
Finally, I find that I misconfigure the "tunnel source" ,make NHRP not working.
It's completed. thank you.
9 Replies 9
hard to tell what you are missing. Are these the full tunnel configs ? On the hub tunnel, try and configure:
ip nhrp redirect
Also, post the output of:
show ip nhrp nhs detail
from the hub and spoke routers...
the spoke router use "show ip nhrp nhs detail":
Spoke#show ip nhrp nhs detail
Legend:E=Expecting replies, R=Responding, W=Waiting
Tunnel0:
172.16.123.3   E priority = 0 cluster = 0  req-sent 809  req-failed 0  repl-recv 0
Pending Registration Requests:
Registration Request: Reqid 17, Ret 64  NHS 172.16.123.3 expired (Tu0)
The Hub router shows:
Hub#show ip nhrp nhs detail
Hub#
tunnel destination in spoke must replace with tunnel mode gre multipoint.
balaji.bandi
on the spoke  add and test
here is some reference :
https://www.cisco.com/c/en/us/support/docs/security-vpn/ipsec-negotiation-ike-protocols/29240-dcmvpn.html
BB
Hello
Looks like your using DMVPN phase 2, Do you have an IGP running as well (rip,ospf,eigrp) if so
try the following:
NHS (Hub router)
interface Tunnel0
no tunnel source GigabitEthernet0/1
NHC (the spoke router)
interface Tunnel0
no tunnel destination 10.100.100.2
Kind Regards
Paul
I try these command and it still not working.
I make sure the hub router can receive the NHRP registration packet from the spoke router
Hello
Would you be able to post configs for both the NHS (hub) and NHC (spoke) please?
Kind Regards
Paul
Post updated config to look.
BB
Hi all,
