NM-1A-E3 load balancing
davidsr
Hi, my customer want to install a CISCO3845 with two NM-1A-E3 and IOS SP Services.Could you tell me if is possible to do load balancing between this two E3 links ? Have you and example ?
spremkumar
Level 9
Level 9
Hi David
AFAIK you need to define equal cost static routes via both the links/interfaces so that you load balance will happen with normal static routes itself.
But would suggest to make sure whether your Cisco 3845 with the current resources installed in it can handle the same ..
regds
Hi, many thanks for your answer...Now this router only has one NM-1A-E3 and the customer want to add another module and do load balancing. Do you think that the CISCO3845 has enought performance to mannage two E3 ?
Many thanks.
