NM-1CE1U
lcd_shouldit
Hi , I have a NM-1CE1U working on my router 2600 , configured with frame-relay . But seems it does not work on my router 2811.
I have check that the replacement is HWIC-1CE1T1-PRI , right ?
But the problem is these two modules have different interface type , I want to keep my cable interface type ( I am not sure what exactly type this cable is , maybe V.35 , please find the attachment ) , and find one module card working on 2800 or 2900 router , can configure frame-relay.
Thank you !
paolo bevilacqua
That connector and cable are obsolete and not produced anymore. You will need to replace card and cable.
Note for frame realy you do not need channelized, regualar VWIC E1 is OK.
lcd_shouldit
Oh, seems the cable is CAB-7KCT1DB15 , right ?
So, if I want this cable connect my 28 or 29 router , which module should I purchase ......
paolo bevilacqua
