NM-2W and HWIC-4B-S/T
ashley_dew
Beginner
Beginner
I wanted to confirm if NM-2W supports HWIC-4B-S/T in the WAN slots.
I have conflicting information:
On NM-2W says that it does not support HWIC modules or the module.
http://www.cisco.com/en/US/customer/prod/collateral/routers/ps259/product_data_sheet09186a00801aa71c.html
On specs of the ISDN card, it says
Supported in NM-1FE2W-V2, NM-1FE1R2W, NM-2FE2W-V2, and NM-2W
Can not be inserted into a mixed-media network module
http://www.cisco.com/en/US/prod/collateral/modules/ps5949/data_sheet_c78_439536.html
I am kind of confused.
Can you please assist or anyone had an experience installing these cards on a NM-2W
Ashley
mvsheik123
Rising star
Rising star
Hi Ashley,
No. It does not supported on NM-2W. Please see the note at the beginning of table 2 in the below link..
http://www.cisco.com/en/US/partner/docs/routers/access/interfaces/nm/hardware/installation/guide/OvrNetM.html
(High-density WAN interface cards (HWICs) are not supported on 1- or 2-slot network modules).
With ref to the second link in your posting- The ISDN card specs comparing the NM-4B-S/T (supported by NM-2W) and HWIC-4B-S/T.
hth
MS
Recognize Your Peers
