I am having an issue configuring a NME-AIR-WLC12-K9 module on a 2921 ISR router running 15.1(4)M2. Under the Integrated Service Engine interface, I do not see the "service-module ip address" options. Any ideas?
Router(config)#interface integrated-Service-Engine 1/0
Router(config-if)#ip unnumbered Gi0/0
Router(config-if)#service?
service-policy
Router(config-if)#
Slot 1:
SM-NM-ADPTR
Port Adapter is analyzed
Port Adapter insertion time 2d11h ago
EEPROM contents at hardware discovery:
PCB Serial Number : FOCXXXXXXXX
Hardware Revision : 1.0
Part Number : 73-12434-04
Top Assy. Part Number : 800-32481-01
Board Revision : E0
Deviation Number : 121778
Fab Version : 05
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : SM-NM-ADPTR
Version Identifier : V01
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF C1 8B 46 4F 43 31 35 34 32 30 47 39 55 40
0x10: 05 F4 41 01 00 82 49 30 92 04 C0 46 03 20 00 7E
0x20: E1 01 42 45 30 88 00 01 DB B2 02 05 03 00 81 00
0x30: 00 00 00 04 00 CB 8B 53 4D 2D 4E 4D 2D 41 44 50
0x40: 54 52 89 56 30 31 00 D9 03 40 C1 CB F3 00 03 40
0x50: 0B E3 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Integrated Service Engine Port adapter, 1 port
Port adapter is analyzed
Port adapter insertion time 2d11h ago
Part Number : 73-10371-04
Top Assy. Part Number : 800-28610-03
Board Revision : A0
Deviation Number : 0
Fab Version : 01
RMA History : 00
Product (FRU) Number : NME-AIR-WLC12-K9
Version Identifier : V03
CLEI Code : IPUCAWCBAA
0x00: 04 FF 40 04 F8 41 01 00 82 49 28 83 04 C0 46 03
0x10: 20 00 6F C2 03 42 41 30 88 00 00 00 00 02 01 C1
0x20: 8B 46 4F 43 31 35 34 33 30 59 58 52 03 00 81 00
0x30: 00 00 00 04 00 CB 90 4E 4D 45 2D 41 49 52 2D 57
0x40: 4C 43 31 32 2D 4B 39 89 56 30 33 20 D9 03 40 C1
0x50: CB C6 8A 49 50 55 43 41 57 43 42 41 41 FF FF FF
