196
Beginner
No access to LAN subnets via Client VPN
Hello all,
We use Shrew Soft VPN Client to make a client VPN connection to our customers Cisco routers.
This works fine, at least for 99% :)
We have this strange situation with 1 of our client routers. We can succesfully establish a client VPN tunnel to the router.
On my Windows 10 machine when I do a "route print" I can see the subnets on customer side are reachable via the tunnel adapter.
However, those subnets are not accessible and can't be pinged. This is the case via 2 different WAN connections on our side. Strange thing is when I create a hotspot on my smartphone, connect my laptop via WiFi to that hotspot, and connect with the client VPN, it DOES work and I can access the subnets on the other side.
Also with the "old" Cisco VPN client on a machine in the same LAN as my laptop I am able to connect and reach the client's subnets just fine. So our WAN side is not blocked by any means by the customers router.
So to sum it up:
laptop on ethernet - shrew soft vpn client -> customer -> no success
laptop via hotspot - shrew soft vpn client -> customer -> success
laptop on ethernet - old cisco vpn client -> success
Any ideas what the root cause might be and how to troubleshoot this ?
Many thanks in advance.
~Will
ps client router is cisco 881 with firmware 15.4(3)M10
i upgrade the firmware yesterday, it didn't work with 15.4(3)M9 as well
Everyone's tags (1)
Content for Community-Ad
July's Community Spotlight Awards
