No create L2VPN on 7600 ES slot
hmedinas
Good Morning,
I try to create a L2VPN on 7609 Router Cisco on Slot type ES but it doesn't recognize the command:
Router(config)#pseudowire-c L2VPN
Router(config-pw)#encaptulation mpls
Router(config-subif)# xconnect 1.1.1.1 10 pw-class L2VPN
MPLS encap is not supported on this circuit
Is it necesary change the connection or is it necessary activate some feature on device?
0 Replies 0
