No Service-module command
fauzi.nugraha
Hi everyone,
I need some help, my client just bought cisco 4331 and want to use voicemail. I've read about this in some articles, they said in 4331 voicemail use service engine interface for CUE.
In my 4331 router, there is serviceengine0/4/0 interface, but when i in to serviceengine0/4/0 i cannot issue "Sevice-module" command, and there is no option for service-module command.
Am i missing something?
Mark Malone
As far as i have seen and read on 4k routers the CUE is virtual and runs in a container , 4k needs a harddrive 50gb min, so you would load an ova onto it for it to operate vmail from the 4k
Cisco Unity Express Virtual on Cisco 4000 Series Integrated Service Routers KVM Service Containers
Cisco Unity Express Virtual also supports operating within the Kernel Virtual Machine (KVM) Service Container on Cisco 4000 Series Integrated Service Routers (Cisco 4000 Series ISR), also called virtual service containers.
A virtual service container is a virtualized environment on the Cisco 4000 Series ISR router. It is also referred to as a virtual machine (VM), virtual service, or container. You can install an application within a virtual service container which runs within the operating system of a device. The application runs in the virtual services container of the operating system of a device. The application is delivered as an open virtual application (OVA), which is a tar file with a .ova extension. The OVA package is installed and enabled on a device through the device CLI. For more information on virtual service containers, see Virtual Services Container.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/unity_exp/compatibility/cuecomp.html
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/unity_exp/rel9_0/install/cue_install_book/cue_virtual_overview.html#id_36795
Good evening,
I encounter the same problem on ISR4321 router. I use as version: isr4300-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin
I followed the cisco procedure contained in the file whose link is below.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/unity_exp/rel9_0/install/cue_install_book/cue_virtual_support_for_kvm.html
However, I can not activate virtual services. is there a procedure to activate the virtual-service?
Thank you for your competition
