05-24-2022 05:28 PM
I am working on getting my router and switch to work with my cable modem. I have gotten the router to see the outside world and ping addresses. I am now working on the switch and having issues. I have my router connected to port 24 on my 2950 cisco switch, and every time I run the command, no switch port comes back as an incompleted command. So I try to enter the IP address and get an error that IP addresses may not be configured on l2 mode. Can someone point me in the right direction? I
configuration
Solved! Go to Solution.
05-24-2022
05:40 PM
- last edited on
05-26-2022
10:28 PM
by
Translator
switch L2->L3
in global <ip routing >
in interface <no switchport> if this not support then
config SVI "VLAN interface" with IP.
05-24-2022 05:53 PM
It seems that you have a layer 2 switch in hands, which is expected for this switch model.
But, with apropriate licesing you can possibly use it as layer 3 device.
However, you need IP service license. You can check with "show version" if it shows
Lan base or IP base, you ned to change the license to IP sercvice.
The problem is that this switch is probably end of everything, so, chances are you can not fix this.
05-24-2022
05:40 PM
- last edited on
05-26-2022
10:28 PM
by
Translator
switch L2->L3
05-24-2022 05:53 PM
