not able ping 8.8.8.8 and no internet access from the corporate network
2 Accepted Solutions
Can you provide more detail as to the logical set up... do you have a firewall and is the firewall allowing icmp and dns out to 8.8.8.8.. are you using 8.8.8.8 as your dns.. do you have NAT configured correctly do you have a default route do you have.... mate please give us more detail no way we can assist if the issue is presented in this manner.. T
Hello
Dont forget to exclued the D/G address
ip dhcp excluded-address 192.168.1.1
res
Paul
Kind Regards
Paul
6 Replies 6
i can able to access intranet and not able to access internet...
in addition to Tinashe's post, four basic things need to be configured: inside interface, outside interface, NAT access list, and NAT translation statement. Below is a sample:
interface FastEthernet0/0
description LAN
ip nat inside
interface GigabitEthernet0/0
description WAN
ip address dhcp
ip nat outside
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
ip nat inside source list 1 interface GigabitEthernet0/0 overload
access-list 1 permit 192.168.1.0
Hello
res
Paul
Kind Regards
Paul
Could you please share a topology and configuration, additional to other members, the ICMP es reciprocal so you should have a path to return the response, so also verify the routing.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
That isn't needed; he doesn't create a DHCP pool and even if he was, the IP address of the local interface is always excluded by default.
