05-18-2008 03:58 AM - edited 03-03-2019 09:59 PM
Is there is any options to have NPE G1/G2 with an additional UTP gig ethernet . As I know the only option for Gig Ethernet is PA-GE which is fibre . Is there is any other router comes with 4 Gig Ethernet ? . In my design a router with 4 UTP gig ethernet
05-18-2008 05:20 AM
PA GE has a GBIT connetor to which you connect a module of your choice including copper.
Note if you're looking for wire-speed routing across all 4 Gbit ports, your best choice would be a layer-3 switch, because the 7200 is incapable of that.
05-18-2008 05:35 AM
Hi ,
What you meant by " PA GE has a GBIT connetor to which you connect a module of your choice including copper " ? Is it possible to connect copper on PA-GE , As I know PA-GE has only fibre GBIC ( either GBIC-LX , GBIC-LH or GBIC-ZX ) . Can you tell me how you can connect a module of copper on PA-GE ??
Have a look in this link
Haris
