08-13-2023
06:27 AM
- last edited on
08-14-2023
10:09 AM
by
Translator
Hello, I've searched and can't find anything specific on this log error message I'm seeing, can anyone assist or point me in the right direction please?
#sh ver
Cisco IOS Software, ME360x Software (ME360x-UNIVERSALK9-M), Version 15.5(3)S4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Mon 26-Sep-16 05:48 by prod_rel_team
ROM: Bootstrap program is WHALES boot loader
BOOTLDR: ME360x Boot Loader (ME360X-HBOOT-M), Version 12.2 [sourdutt-loader_release_ledfix 100]
WEISER-PE-1 uptime is 6 years, 29 weeks, 6 days, 2 hours, 22 minutes
System restarted at 03:26:27 MST Tue Jan 17 2017
System image file is "flash:/me360x-universalk9-mz.155-3.S4/me360x-universalk9-mz.155-3.S4.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: AdvancedMetroIPAccess
License Type: Permanent
Next reload license Level: AdvancedMetroIPAccess
cisco ME-3600X-24FS-M (PowerPC8572) processor (revision B0) with 983040K/65528K bytes of memory.
Processor board ID xxx
Last reset from power-on
5 Virtual Ethernet interfaces
25 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
1536K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 0C:68:03:C6:B6:80
Motherboard assembly number : 73-12693-07
Motherboard serial number : FOC17261352
Model revision number : B0
Motherboard revision number : B0
Model number : ME-3600X-24FS-M
System serial number : xxx
Top Assembly Part Number : 800-32951-01
Top Assembly Revision Number : D0
Version ID : V01
CLEI Code Number : xxxx
Configuration register is 0xF
Solved! Go to Solution.
08-13-2023 10:16 AM
- This looks like a resource problem on the device failing to allocate space for mac addresses ; consider using https://software.cisco.com/download/home/283095597/type/280805680/release/15.6.2-SP8 , latest advisory and check if the problem is persistent (in case of bugs) . However another potential cause can be network traffic storms , and or 'incorrect traffic' on the network ; to follow-up on these kind of events it is advisable to configure a syslog server on the device and check logs arriving on the syslog server at regular intervals ,
M.
08-13-2023 10:16 AM
M.
