NTP Security on IOS devices
Daniel-nl
We have lots of Cisco IOS devices (2800/2900 routers and some 3750 Catalyst switches), and need to secure them against NTP reflection attacks.
Actually, there are 2 kind of attacks:
  1. NTP Mode 7 query for MONLIST
  2. NTP Mode 6 query for READVAR *)
While mode 7 queries are easy to handle with ntp access-lists, mode 6 queries are still possible. This is an output of a Cisco IOS Router with configured ntp access-lists:
-bash-4.1$ ntpq -c rv XX.XX.XX.XX
assID=0 status=062c leap_none, sync_ntp, 2 events, event_12,
version="4", processor="unknown", system="UNIX", leap=00, stratum=3,
precision=-21, rootdelay=?, rootdisp=, refid=XX.XX.XX.XX,
reftime=d7d3e69d.9b75682c  Mon, Sep 29 2014 16:09:33.607,
clock=d7d3e6a1.2f22b147  Mon, Sep 29 2014 16:09:37.184, peer=32663,
tc=10, mintc=3, offset=?, frequency=?, sys_jitter=, clk_jitter=,
Is there a way to prevent an IOS device to answer to mode 6 queries without configuring access lists directly at the WAN ports to discard all incoming UDP traffic to port 123?
Thank you in advance.
*) https://www.shadowserver.org/wiki/pmwiki.php/Services/NTP-Version
Leo Laohoo
You can minimize NTP magnification attacks in several ways:
1.  Get a firewall/IPS/IDS;
2.  Use a Loopback IP Address and specify/allow the subnet the Loopback IP address for SNTP/NTP using ACL;
3.  Create an NTP authentication.
In this case, it is a confirmed and already fixed bug:
https://tools.cisco.com/bugsearch/bug/CSCuj66318
Shadowhawk this issue does not appear to be fixed in current versions of IOS-XE 03.06.06E, 150-2.SG11, and so on. Would you know if Cisco intends to update the NTP code being embedded into IOS, IOS-XE, and so on?
