On which case we can say there is high interface utilisation
krahulbgp
Either
case 1 when transmit percentage is high
Case 2 when  Received percentage is high
Or Both should high
Joseph W. Doherty
Either case or both cases.
However, tx utilization's significance is a bit different from rx utilization, as the former's queuing can distort utilization.
For example, assume 10 ingress interfaces all egress 1 interface.  Further, assume, 10 frames/packets all arrive concurrently, but the egress interface only can buffer 5.  The tx usage will only account for the 5 frames/packets transmitted, but 50% of the traffic was lost.
Also keep in mind utilization is but a total possible capacity measurement over some time interval, actual usage is always zero or 100%.  Such a measurement, alone, tells little about the interface, as all interfaces (themselves) should be able to sustain 100% usage, in and out, concurrently.
