One fix
Im trying to ping pc to laptop but i cant seem to find the error.
Your routers only have directly connected routes so they cannot forward packets to the remote subnets.
Add these static routes to the router configurations -
Router0
ip route 192.168.2.0 255.255.255.0 <Router1's 10.0.1.x IP address>
Router1
ip route 192.168.1.0 255.255.255.0 <Router0's 10.0.1.x IP address>
ip route 192.168.2.0 255.255.255.0 <Router2's 10.0.2.x IP address>
Router2
ip route 192.168.1.0 255.255.255.0 <Router1's 10.0.2.x IP address>
Jon
5 Replies 5
Jon Marshall
As you have only posted a diagram we can only guess.
Assuming you have setup the vlans and ports correctly then check the routing tables of all the routers as each router needs to know about both subnets.
If you want more specific help then post the configs.
Jon
I was not able to set up the vlan correctly
These are the ip route screenshots
Router0
Router1
Router2
Jon
balaji.bandi
here is my observation :
1. you do not have route entry for the router to establish routing topology
2. you need to set up static routes between router to exchange route
3. you do not have any route as per output.
suggest to start with below video to understand basic routing and you will learn :
https://www.youtube.com/watch?v=PtKsssg63-A
still not working post all the device configuration
BB
