One Subnet, Two routers!?
scottwilliamson
Level 2
Level 2
Hi All,
Our server development team have a requirement to have the same subnet in two different locations (apparently it will facilitate the deployment of DR servers and such) that is served by 6509s and a routed link between. Is there a technique or feature we can use to accomodate them that is available on the 6509, perhaps a tunneling protocol of some kind? I've read briefly about OTV but this seems to be available on ither (higher end?) kit such as the Nexus switches. Is HSRP a possible solution (we could arrange a L2 link between the two sites)?
The 6509s are running s72033-ipservicesk9_wan-mz.122-33.SXJ2 at one site and s72033-ipservicesk9_wan-mz.122-33.SXI5 at the other. Both have the VSS operational.
Many thanks in advance for any suggestions or even confirmation that such a thing cannot be done on our current configuration.
Scott
Hello
it depends on how your two sites are currently connected.
Two technologies come to mind
ATOM
L2TPv3
res
paul
Sent from Cisco Technical Support Android App
Kind Regards
Paul
