06-19-2013 04:49 PM - edited 03-04-2019 08:15 PM
Hello , I have 2 equipment ONS 15305, 1 of them with STM-1 and another STM-4. What is the replacement of such equipment now, Help to identify the equipment to replace him but other than the ONS 15454 MSTP, I want something cheaper.
Thanks you,
SFP
Solved! Go to Solution.
06-27-2013 11:45 AM
Perhaps the 15310-MA SDH would work.
http://www.cisco.com/en/US/partner/products/ps9458/index.html
06-27-2013 07:37 AM
15454 is currently recommended for migration from the 15305.
Do you only require STM-1 and STM-4 circuits then? I'll see if I can find anything else. /Doug.
07-18-2013 11:24 PM
I have this old ONS
ONS 15305 Optical Modules |
15305-S1.1-2-LC= | 15305 2xSTM-1, SH, 1310nm, Optical Service Module |
ONS 15305 Ethernet Modules |
15305-E100-8-W= | 15305 8xFE 10/100BaseTX Service Module w WAN Mapper |
ONS 15305 TDM Modules and Accessories |
15305-E1-8= | 15305 8xE1 120 Ohm (RJ-45 Connectors) Service Module |
I need that same funtion within ASR, can you tell me if this resolve that config.
Item Name | Description | Quantity |
ASR1002-X | Cisco ASR1002-X Chassis 6 built-in GE Dual P/S 4GB DRAM | 1 |
CON-PSUP-ASR1002X | PRTNR SUP 24X7X4 Csc ASR1002-X Chs 6 blt-in GE Dual P/S 4 | 1 |
SPA-8X1FE-TX-V2 | Cisco 8-Port Fast Ethernet (TX) Shared Port Adapter | 1 |
CON-PSUP-8X1FETV2 | PRTNR SUP 24X7X4 8-Pt Fast Enet TX Shared Pt Adptr | 1 |
ASR1000-SPA | SPA for ASR1000; No Physical Part; For Tracking Only | 1 |
ASR1002-PWR-AC | Cisco ASR1002 AC Power Supply | 2 |
CAB-AC-RA | Power Cord110V Right Angle | 2 |
M-ASR1002X-4GB | Cisco ASR1002-X 4GB DRAM | 1 |
ASR1002X-HD-BLANK | Blank Cover for ASR1002-X HDD | 1 |
SASR1K2XU-38S | Cisco ASR 1002-X IOS XE UNIVERSAL - NO ENCRYPTION | 1 |
SLASR1-IPB | Cisco ASR 1000 IP BASE License | 1 |
CON-PSUP-SLASR1IK | PRTNR SUP 24X7X4 Cisco ASR 1000 IP BASE License | 1 |
SPA-1XOC12-POS | 1-port OC12/STM4 POS Shared Port Adapters | 1 |
CON-PSUP-1XOC12 | PRTNR SUP 24X7X4 1-port OC12/STM4 | 1 |
SFP-OC12-SR | OC12/STM4 SFP Short Reach | 1 |
07-25-2013 09:10 AM
Hi Santiago,
For component ordering support, may I suggest the partner community? (I'm assuming you're a partner)
Lauren
06-27-2013 11:45 AM
