optimize my pppoe server config
hello , i have ASR1006 with esp100
i configure it as pppoe server with freeraduis
i have now more of 5000 client
but the service is not stable  , sometime user's have many time delay to connecting
sometime user auto disconnected , and sometime not all user's can authentication , below is my config
what i can add or remove or change in my config to make it optimize and fix my issues
aaa group server radius ANAS
 server name ANAS
aaa server radius dynamic-author
 client x.x.x.x server-key 7 121F0C1517190E05242F342D212031015E44
 server-key 7 104D8220A0618
 auth-type any
 ignore session-key
 ignore server-key
bba-group pppoe PPPOE_OUT
 virtual-template 3
 sessions per-vc limit 64000
 sessions per-mac limit 64000
 sessions per-vlan limit 64000 inner 64000
interface Virtual-Template3
 mtu 1460
 ip unnumbered Loopback0
 no ip redirects
 ip nat inside
 ip tcp adjust-mss 1400
 ip policy route-map ROUTE-TV
 no logging event link-status
 timeout absolute 4320 0
 peer default ip address pool interface localpool
 keepalive 5
 ppp authentication chap
 ppp ipcp dns 8.8.8.8 8.8.4.4
 ppp timeout retry 80
 ppp timeout authentication 60
 ip virtual-reassembly
interface Port-channel1.905
 description PPPOE-QAYRIA
 encapsulation dot1Q 905
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 pppoe enable group PPPOE_OUT
radius-server attribute 44 include-in-access-req all
radius-server attribute 31 mac format one-byte delimiter colon
radius-server attribute 31 send nas-port-detail mac-only
radius-server attribute nas-port-id include circuit-id
radius-server timeout 10
radius-server unique-ident 38
radius-server key 7 1048001B0005100A02003A2E363D20277B41
aaa authentication ppp default group radius
aaa authorization network default group radius
aaa accounting delay-start all
aaa accounting nested
aaa accounting update periodic 1
aaa accounting network default start-stop group radius
aaa accounting system default start-stop group radius
interface Virtual-Template1
 mtu 1460
 no ip redirects
 ip nat inside
 keepalive 6
5 Replies 5
Giuseppe Larosa
Hello @anas.abdullkarim ,
for sure the following line in the bba-group definition is too much
you should use a per MAC address limit of two to allow a user to reconnect while its previous PPPoE session is deleting.
Hope to help
Giuseppe
try and strip the virtual template to the most basic config (changes and additions marked in bold):
server name ANAS
auth-type any
ignore session-key
ignore server-key
virtual-template 3
--> no sessions per-vc limit 64000
--> no sessions per-mac limit 64000
--> no sessions per-vlan limit 64000 inner 64000
--> no mtu 1460
no ip redirects
ip nat inside
--> no ip tcp adjust-mss 1400
--> no ip policy route-map ROUTE-TV
--> no timeout absolute 4320 0
--> keepalive 30
--> no ppp timeout retry 80
--> no ppp timeout authentication 60
no ip redirects
no ip unreachables
no ip proxy-arp
--> no mtu 1460
no ip redirects
ip nat inside
--> keepalive 30
thanks for reply , but why i delete
someitme i have customer he have more of 1000 client is his switch
maybe my router see it as one mac addreess
in that case, leave those lines in there. I just want to see if the problem persists if you take all the extra stuff out...
