Option 125 invalid
Adeel Hasany
I have a Mitel phone looking to pick IP from the remote DHCP server. But it get stuck on discovery DHCP. Upon debugging ip dhcp server packets
I am geting following error:
Apr 20 09:21:14.175: DHCPD: client's VPN is .
Apr 20 09:21:14.175: DHCPD: No option 125
Apr 20 09:21:14.175: DHCPD: Sending notification of DISCOVER:
Apr 20 09:21:14.175: DHCPD: htype 1 chaddr 0800.0f28.0de1
Apr 20 09:21:14.175: DHCPD: remote id 020a00000aca0101010000c8
Apr 20 09:21:14.175: DHCPD: circuit id 00000000
Apr 20 09:21:14.175: DHCPD: Seeing if there is an internally specified pool class:
Apr 20 09:21:14.175: DHCPD: Found previous binding with giaddr 192.168.10.1
Apr 20 09:21:14.175: DHCPD: setting giaddr to 192.168.10.1.
Apr 20 09:21:14.175: DHCPD: BOOTREQUEST from 0108.000f.280d.e1 forwarded to 192.168.2.115.
Apr 20 09:21:14.175: DHCPD: BOOTREQUEST from 0108.000f.280d.e1 forwarded to 192.168.1.115.
interface GigabitEthernet0/1.200
description Voice VLAN
encapsulation dot1Q 200
ip dhcp relay information trusted
ip dhcp relay information option-insert none
ip dhcp relay information check-reply none
ip address 192.168.10.1 255.255.255.128
ip helper-address 192.168.1.115
ip helper-address 192.168.2.115
no ip redirects
no ip unreachables
ip directed-broadcast
no ip proxy-arp
ip flow ingress
Ad
0 Replies 0
