OSPF and EIGRP
The_guroo_2
Level 2
Level 2
just wanna know which layer4 protocol ospf and eigrp uses??? and whats the port no....like BGP is TCP based and uses port 179.....so just wanna curious abt ospf and eigrp and if u could tell me abt rip and igrp as well that will make my doubts really clear........cheers and thanks in advance
Harold Ritter
OSPF uses IP protocol number 89 and EIGRP uses 88. RIP is UDP based and uses port 520. IGRP uses IP protocol number 9.
To find out about the assigned IP protocol numbers, please refer to the following document:
http://www.iana.org/assignments/protocol-numbers
Hope this helps,
Does RIP v2 works as application like BGP ( working on top of TCP) ?
RIP v2 is like v1 on top of UDP unlike BGP which is on TCP.
Wilson Samuel
royalblues
Level 10
Level 10
OSPF, EIGRP and IGRP are Directly encapsulated in the IP packet. They just add their headers and hence rely on all the properties of the IP datagram.
OSPF - IP datagram 89
EIGRP - IP datagra 88
IGRP - IP datagram 9
RIP uses UDP 520
Narayan
