OSPF: ASBR in Backbone Area. How routes are sent to other area routers?
rais
Level 7
Level 7
How would OSPF behave when one of the backbone routers becomes an ASBR? Would the external routes be converted to type-5 automatically inside area backbone? How are these routes sent to other routers within say , area 1.
Thanks.
Reza Sharifi
ASBR routes/summary get injected in to area 0 by ABR router and they appear in are 0 as type 5 LSA.
Depends on the area, if the area is a normal area, then it get all of the LSAs, including type 5.  But if for example area 1 is stub with no summary, then LSA types 3, 4,5 will not appear in it.  It only gets a default router from the ABR router.
Reza
Reza,
Thanks for the reply.
What happens if the ASBR is part of backbone. Meaning there is no ABR between ASBR and backbone. Would the ASBR still inject routes as type-5 into backbone?
Thanks.
Yes the ASBR will inject type 5 LSAs which will be received by all other backbone/area 0 routers.
Rick
Rick
Yeah.
Say if you have routers connected like so: R1-R2-R3
And all of them are in area 0 (backbone), then if you enter the following on R2:
router ospf X
redistribute connected subnets
Then the R2 will become an ASBR even though it's a backbone router. If some interfaces (e.g. loopback100) is not covered by the network statement under router ospf process, the routes will appear in the RIB as O E2
