OSPF Connection between ASA 5525 & Nexus 9504s
sebbing
Hello all,
I am having a bit of an issue with trying to get an ASA 5525 to form a neighborship with a Nexus 9504. They can see and communicate with each other via layer2 VLAN connection.
Trying to figure out what I am doing wrong. Here is stippets of the interfaces from the Nexus and the ASA.
Nexus
show interface vlan 3
interface Vlan3
description FIREWALL-INSIDE-Default-Gateway
no shutdown
mtu 9000
no ip redirects
ip address 10.50.2.8/24
no ipv6 redirects
ip router ospf 1 area 0.0.0.100
hsrp version 2
hsrp 3
name FIREWALL-INSIDE
preempt
priority 90
ip 10.50.2.2
ASA
ASA-03# sh run router
router ospf 1
router-id 10.50.2.5
network 10.50.2.0 255.255.255.0 area 100
network 10.60.0.128 255.255.255.128 area 100
area 100
log-adj-changes
I guess the question I have is that when I try to put in area 0.0.0.100 on the ASA it transfers it to what you see here with only 100. Is that a big deal on that matter or is it still the same "area"?
I am not sure if it is a problem but the ASA is connected to a 2960 switch, which is then connected to a pair of 93180 layer 2 nexus switches. Those are then connected to the 9504s . Pings and traceroutes go both ways at this point, so I am not sure where the breakdown is happening. Can someone assist me with this?
Thanks!
33 Replies 33
That got us somewhere!
9504-01# ping multicast 224.0.0.5 int vlan 3
PING 224.0.0.5 (224.0.0.5): 56 data bytes
Request 0 timed out
Request 1 timed out
Request 2 timed out
Request 3 timed out
Request 4 timed out
--- 224.0.0.5 ping multicast statistics ---
5 packets transmitted,
0 packets received, 100% packet loss
9504-01# ping multicast 224.0.0.6 int vlan 3
PING 224.0.0.6 (224.0.0.6): 56 data bytes
Request 0 timed out
Request 1 timed out
Request 2 timed out
Request 3 timed out
Request 4 timed out
--- 224.0.0.6 ping multicast statistics ---
9504-01#
show ip ospf traffic vlan3
show ip ospf interface vlan3
please share this of NSK
Well crap..  Once you put that in and I went to get the
show
command on that, I wonder if I just found the problem.
9504-01# sh ip ospf int vlan 3
Vlan3 is up, line protocol is up
IP address 10.50.2.8/24
Process ID 1 VRF default, area 0.0.0.100
Enabled by interface configuration
State DR, Network type BROADCAST, cost 40
Index 12, Passive interface
9504-01#
If that truly is passive, that would stop the transmission of the OSPF I would think. Am I correct?
Thanks!
I inform you in my previous post that check this point,
anyway
I am so glad you get the issue,
Yes Passive making NSK not send Hello and never establish the OSPF.
no passive this interface and check the OSPF.
