OSPF Database & routing table
actkillerby
Why would there be discrepancies between the ospf database and the entries in the routing table. If I do show ip ospf database there are a significant number of entries that are not shown but are in the network list under router ospf....
Why would this be? We are having occasional connectivity problems with 2 of the subnets that are not in the ospf database but are in the network router list.
Any help you can give is appreciated.
Alex
hi Alex,
As I said earlier, all routers with in an area would have the same topology database. That means, same entries.
The only thing i think u are missing is, you have to check it under the Router LSA for the advertising router.
show ip ospf database router <192.168.162.1>
Check the same command on the router in which u suspect its not there.
regards,
Sudeep
32 Replies 32
John Blakley
A couple of things that I can think of would be that you could be learning from a different routing protocol with a lower AD. If you're only running OSPF, the route needs to be accessible or it won't be put in the routing table. What type of LSAs are missing? Summary, External?
HTH, John *** Please rate all useful posts ***
The networks we are having issues with are all internal
This is the list of networks from the running config
router ospf 2
log-adjacency-changes
network 10.2.0.0 0.0.255.255 area 0
network 10.89.160.0 0.0.0.63 area 0
network 10.89.160.64 0.0.0.63 area 0
network 10.89.160.128 0.0.0.63 area 0
network 10.89.162.64 0.0.0.63 area 0
network 10.89.163.128 0.0.0.63 area 0
network 10.89.164.0 0.0.0.127 area 0
network 10.89.164.128 0.0.0.127 area 0
network 10.89.171.0 0.0.0.127 area 0
network 10.89.174.0 0.0.0.255 area 0
network 10.115.0.0 0.0.0.255 area 0
network 10.115.1.64 0.0.0.63 area 0
network 10.115.5.0 0.0.0.63 area 0
network 10.115.7.128 0.0.0.127 area 0
network 10.115.17.0 0.0.0.127 area 0
network 10.115.18.0 0.0.0.255 area 0
network 10.115.19.0 0.0.0.255 area 0
network 10.115.21.0 0.0.0.255 area 0
network 10.115.22.0 0.0.0.255 area 0
network 10.115.29.0 0.0.0.255 area 0
network 10.115.30.0 0.0.0.255 area 0
network 10.115.32.0 0.0.0.255 area 0
network 10.115.33.0 0.0.0.255 area 0
network 10.115.39.0 0.0.0.255 area 0
network 10.115.40.0 0.0.0.255 area 0
network 10.115.41.0 0.0.0.255 area 0
network 10.115.45.0 0.0.0.255 area 0
network 10.115.46.0 0.0.0.255 area 0
network 10.115.50.0 0.0.0.255 area 0
network 10.115.60.0 0.0.1.255 area 0
network 10.115.64.128 0.0.0.3 area 0
network 10.115.64.136 0.0.0.3 area 0
network 10.115.64.144 0.0.0.15 area 0
network 10.115.76.0 0.0.3.255 area 0
network 10.115.96.0 0.0.0.255 area 0
network 10.115.98.0 0.0.1.255 area 0
network 10.115.104.0 0.0.7.255 area 0
network 172.20.1.0 0.0.0.255 area 0
network 172.20.2.0 0.0.0.255 area 0
network 172.20.22.0 0.0.0.255 area 0
network 172.20.50.0 0.0.0.255 area 0
network 172.20.70.0 0.0.0.255 area 0
network 172.20.71.0 0.0.0.255 area 0
network 172.20.250.0 0.0.0.255 area 0
network 192.168.144.0 0.0.0.127 area 0
network 192.168.161.0 0.0.0.127 area 0
network 192.168.162.2 0.0.0.0 area 0
network 192.168.162.16 0.0.0.3 area 0
network 192.168.162.24 0.0.0.3 area 0
network 192.168.162.64 0.0.0.15 area 0
network 192.168.177.0 0.0.0.255 area 0
network 192.168.184.0 0.0.3.255 area 0
network 192.168.205.0 0.0.0.255 area 0
network 194.101.26.0 0.0.0.255 area 0
and this from the show ip ospf database command
       OSPF Router with ID (192.168.162.2) (Process ID 2)
                Router Link States (Area 0)
Link ID         ADV Router      Age         Seq#       Checksum Link count
192.168.162.1   192.168.162.1   439         0x80026088 0x3139   30
192.168.162.2   192.168.162.2   1963        0x800261AD 0xD774   43
192.168.162.3   192.168.162.3   289         0x8001EF1E 0x1920   58
192.168.162.7   192.168.162.7   789         0x80004C48 0x2A41   25
192.168.162.8   192.168.162.8   974         0x800122B8 0xE719   25
                Net Link States (Area 0)
10.89.164.3     192.168.162.3   289         0x800041D6 0xADBD
10.89.164.131   192.168.162.3   289         0x800041D7 0xA643
10.89.184.3     192.168.162.3   289         0x80000C4C 0x7424
10.115.0.5      192.168.162.2   1963        0x800001B2 0x6774
10.115.1.193    192.168.162.1   439         0x800001BB 0x87CC
10.115.6.2      192.168.162.3   289         0x80000C4C 0x77F9
10.115.18.1     192.168.162.2   1963        0x80000C4C 0x74B4
10.115.32.2     192.168.162.2   1963        0x80000C4C 0xCF4A
10.115.46.3     192.168.162.3   289         0x800041DB 0x7EC4
10.115.50.2     192.168.162.3   289         0x80000C4C 0x1BE9
10.115.64.129   192.168.162.1   439         0x800001B3 0xBD64
10.115.64.133   192.168.162.1   439         0x800001DE 0x4DA4
10.115.64.138   192.168.162.3   797         0x800001B3 0x6BA9
10.115.64.145   192.168.162.1   439         0x800001E1 0x5983
10.115.97.2     192.168.162.7   789         0x8000257F 0xC6B4
10.115.98.3     192.168.162.7   789         0x80002584 0x7BE8
10.115.104.4    192.168.162.3   289         0x80000C4D 0x4E73
10.115.112.8    192.168.162.7   789         0x80001EEA 0x23DE
10.115.113.2    192.168.162.7   789         0x80004133 0xDEFB
10.115.113.66   192.168.162.7   789         0x80004132 0x5E3D
10.115.113.131  192.168.162.8   974         0x80001EEC 0xBB06
10.115.113.194  192.168.162.7   789         0x80004132 0x59C1
10.115.114.2    192.168.162.7   789         0x8000257E 0x9119
10.115.114.130  192.168.162.7   789         0x80004132 0xD089
10.115.115.131  192.168.162.8   974         0x80001EEC 0x24DB
10.115.116.2    192.168.162.7   789         0x80004132 0x3EDA
10.115.116.130  192.168.162.7   789         0x80004132 0x395F
10.115.117.2    192.168.162.7   789         0x80004132 0x33E4
10.115.117.130  192.168.162.7   789         0x80004132 0x2E69
10.115.118.2    192.168.162.7   789         0x8000257F 0xE104
10.115.118.130  192.168.162.7   789         0x80004131 0x2572
10.115.119.2    192.168.162.7   789         0x8000257F 0xD60E
10.115.120.2    192.168.162.7   789         0x80004132 0x1203
10.115.125.2    192.168.162.8   974         0x80000C53 0x2B78
172.20.1.4      192.168.162.7   789         0x80002586 0x64F4
192.168.76.3    192.168.162.7   789         0x80004132 0x25AF
192.168.144.2   192.168.162.2   1963        0x800001BA 0x983F
192.168.161.3   192.168.162.1   439         0x800001B3 0xCE01
192.168.176.14  192.168.162.3   289         0x80000C4C 0x5F30
192.168.177.3   192.168.162.2   1963        0x80000C4C 0xBEDC
The current networks we are having connectivity issues are 10.115.21.0 and 10.115.40.0
Thansk
Alex
What IOS and device is this? Do you have the issue with the same two networks or does it vary?
It can vary as to which network it is and is really random as it can be happening today and not in a weeks time.
Our core routers are Cisco 6509 running Version 12.1(11b)E4 with Supervisor 2 engines.
We have been investigating this on and off for several months and today I noticed this in the ospf database and think this is the issue.
Alex
I see network statements configured under router ospf for these networks. But we do not know if there are interfaces that are up/up that match the network statements. Perhaps posting the output of show ip interface brief would be a starting place to determine this.
Rick
Rick
Hi Rick
As requested
XXXXXXXX#sh ip interface brief
Interface                  IP-Address      OK? Method Status                Protocol
Vlan1                      unassigned      YES TFTP   up                    up
Vlan2                      10.115.64.130   YES manual up                    up
Vlan4                      10.115.64.137   YES manual up                    up
Vlan100                    192.168.144.2   YES NVRAM  up                    up
Vlan177                    192.168.177.3   YES NVRAM  up                    up
Vlan201                    unassigned      YES manual up                    up
Vlan205                    10.115.50.3     YES manual up                    up
Vlan303                    10.115.104.3    YES manual up                    up
Vlan400                    10.115.0.5      YES manual up                    up
Vlan402                    10.115.1.65     YES NVRAM  up                    up
Vlan426                    10.115.7.129    YES NVRAM  up                    up
Vlan445                    10.115.17.1     YES NVRAM  up                    up
Vlan446                    10.115.18.1     YES manual up                    up
Vlan447                    10.115.19.1     YES NVRAM  up                    up
Vlan449                    10.115.21.1     YES NVRAM  up                    up
Vlan450                    10.115.22.1     YES manual up                    up
Vlan457                    10.115.29.1     YES NVRAM  up                    up
Vlan458                    10.115.30.1     YES NVRAM  up                    up
Vlan460                    10.115.32.2     YES manual up                    up
Vlan461                    10.115.33.1     YES NVRAM  up                    up
Vlan467                    10.115.39.1     YES NVRAM  up                    up
Vlan468                    10.115.40.1     YES manual up                    up
Vlan469                    10.115.41.1     YES NVRAM  up                    up
Vlan473                    10.115.45.1     YES NVRAM  administratively down down
Vlan474                    10.115.46.2     YES manual up                    up
Vlan500                    192.168.161.4   YES NVRAM  up                    up
Vlan501                    10.115.64.146   YES manual up                    up
Vlan600                    10.115.96.2     YES manual administratively down down
Vlan601                    unassigned      YES TFTP   up                    up
Vlan700                    unassigned      YES manual up                    up
Vlan814                    10.89.160.65    YES manual up                    up
Vlan815                    10.89.160.129   YES manual up                    up
Vlan822                    10.89.162.65    YES manual up                    up
Vlan827                    10.89.163.129   YES manual up                    up
Vlan830                    10.89.164.2     YES manual up                    up
Vlan831                    10.89.164.130   YES manual up                    up
Vlan844                    10.89.171.1     YES manual up                    up
Vlan850                    10.89.174.1     YES manual up                    up
Vlan1001                   172.20.1.2      YES manual up                    up
GigabitEthernet1/1         unassigned      YES unset  up                    up
GigabitEthernet1/2         unassigned      YES unset  up                    up
GigabitEthernet2/1         unassigned      YES unset  up                    down
GigabitEthernet2/2         unassigned      YES unset  up                    down
GigabitEthernet2/3         unassigned      YES unset  up                    down
GigabitEthernet2/4         unassigned      YES unset  up                    down
GigabitEthernet2/5         unassigned      YES unset  up                    down
GigabitEthernet2/6         unassigned      YES unset  up                    up
GigabitEthernet2/7         unassigned      YES unset  administratively down down
GigabitEthernet2/8         unassigned      YES unset  administratively down down
GigabitEthernet2/9         unassigned      YES unset  administratively down down
GigabitEthernet2/10        unassigned      YES unset  administratively down down
GigabitEthernet2/11        unassigned      YES unset  administratively down down
GigabitEthernet2/12        unassigned      YES TFTP   up                    down
GigabitEthernet2/13        unassigned      YES unset  administratively down down
GigabitEthernet2/14        unassigned      YES unset  administratively down down
GigabitEthernet2/15        unassigned      YES unset  up                    up
GigabitEthernet2/16        unassigned      YES unset  administratively down down
GigabitEthernet3/1         unassigned      YES unset  up                    up
GigabitEthernet3/2         unassigned      YES unset  up                    up
GigabitEthernet3/3         unassigned      YES unset  up                    up
GigabitEthernet3/4         unassigned      YES unset  up                    up
GigabitEthernet3/5         unassigned      YES unset  up                    up
GigabitEthernet3/6         unassigned      YES unset  up                    up
GigabitEthernet3/7         unassigned      YES unset  up                    up
GigabitEthernet3/8         unassigned      YES unset  up                    up
GigabitEthernet3/9         194.101.26.40   YES NVRAM  up                    up
GigabitEthernet3/10        unassigned      YES unset  up                    up
GigabitEthernet3/11        unassigned      YES unset  up                    up
GigabitEthernet3/12        unassigned      YES unset  up                    up
GigabitEthernet3/13        unassigned      YES unset  up                    up
GigabitEthernet3/14        unassigned      YES unset  up                    up
GigabitEthernet3/15        unassigned      YES unset  up                    up
GigabitEthernet3/16        unassigned      YES unset  up                    up
FastEthernet4/1            unassigned      YES unset  administratively down down
FastEthernet4/2            unassigned      YES TFTP   administratively down down
FastEthernet4/3            unassigned      YES TFTP   administratively down down
FastEthernet4/4            unassigned      YES TFTP   administratively down down
FastEthernet4/5            unassigned      YES TFTP   administratively down down
FastEthernet4/6            unassigned      YES TFTP   administratively down down
FastEthernet4/7            unassigned      YES TFTP   administratively down down
FastEthernet4/8            unassigned      YES TFTP   administratively down down
FastEthernet4/9            unassigned      YES TFTP   administratively down down
FastEthernet4/10           unassigned      YES TFTP   administratively down down
FastEthernet4/11           unassigned      YES TFTP   administratively down down
FastEthernet4/12           unassigned      YES TFTP   administratively down down
FastEthernet4/13           unassigned      YES TFTP   administratively down down
FastEthernet4/14           unassigned      YES TFTP   administratively down down
FastEthernet4/15           unassigned      YES TFTP   administratively down down
FastEthernet4/16           unassigned      YES TFTP   administratively down down
FastEthernet4/17           unassigned      YES TFTP   administratively down down
FastEthernet4/18           unassigned      YES TFTP   administratively down down
FastEthernet4/19           unassigned      YES TFTP   administratively down down
FastEthernet4/20           unassigned      YES TFTP   administratively down down
FastEthernet4/21           unassigned      YES TFTP   administratively down down
FastEthernet4/22           unassigned      YES TFTP   administratively down down
FastEthernet4/23           unassigned      YES TFTP   administratively down down
FastEthernet4/24           unassigned      YES unset  up                    up
GigabitEthernet7/1         unassigned      YES unset  up                    up
GigabitEthernet7/2         unassigned      YES unset  up                    up
GigabitEthernet7/3         unassigned      YES unset  up                    up
GigabitEthernet7/4         unassigned      YES unset  up                    up
GigabitEthernet7/5         unassigned      YES unset  up                    up
GigabitEthernet7/6         unassigned      YES unset  up                    up
GigabitEthernet7/7         unassigned      YES unset  up                    up
GigabitEthernet7/8         unassigned      YES unset  up                    up
GigabitEthernet7/9         unassigned      YES unset  up                    up
GigabitEthernet7/10        unassigned      YES unset  up                    up
GigabitEthernet7/11        unassigned      YES unset  up                    up
GigabitEthernet7/12        unassigned      YES unset  up                    up
GigabitEthernet7/13        unassigned      YES unset  up                    down
GigabitEthernet7/14        unassigned      YES unset  up                    up
GigabitEthernet7/15        unassigned      YES unset  up                    down
GigabitEthernet7/16        unassigned      YES unset  up                    up
Port-channel1              unassigned      YES NVRAM  up                    up
Port-channel2              unassigned      YES NVRAM  up                    up
Port-channel3              unassigned      YES NVRAM  administratively down down
Loopback0                  192.168.162.2   YES NVRAM  up                    up
ISDX_Room#sh ip interface brief
Alex
Thank you for the information that I requested. It does show that there appear to be networks that should match the network statements. So for the next step I would ask that you post the output of show ip ospf interface and also the running config for interfaces vlan449 and vlan468/
Rick
Rick
Hi Alex,
Since these are all directly connected interfaces, it would be part of the router LSA.  Please check if those interface/ip ranges are mentioned under the following output.,
"show ip ospf database router 192.168.162.2"
Also these addresses can come under "network LSA", only if its a ABR. This is because, the LInk ID would be the interface/subnet address.
Let me know if tht helps
Sudeep
Morning Sudeep
both of the networks show as seen below
  Link connected to: a Stub Network
   (Link ID) Network/subnet number: 10.115.21.0
   (Link Data) Network Mask: 255.255.255.0
    Number of TOS metrics: 0
     TOS 0 Metrics: 15
    (Link ID) Network/subnet number: 10.115.40.0
      TOS 0 Metrics: 15
Hello Alex,
God morning and thanks for the update.
So now u see it in your database under inside Router LSA.  Did that answer your question
regards,
Sudeep
Hi Sudeep
I am more confused now.  I can see it when I enter the command
but when I connect to router 192.168.162.2 and issue the command
"show ip ospf database"
i cannot see the networks.  Surely I should be able to see it as well when running both commands
Sudeep means that you won't see these subnets on ospf database on this router because it directly connected:
Vlan449 is up, line protocol is up
  Internet Address 10.115.21.1/24, Area 0
  Process ID 2, Router ID 192.168.162.2, Network Type BROADCAST, Cost: 15
  Transmit Delay is 1 sec, State DR, Priority 1
  Designated Router (ID) 192.168.162.2, Interface address 10.115.21.1
  No backup designated router on this network
  Timer intervals configured, Hello 10, Dead 40, Wait 40, Retransmit 5
    Hello due in 00:00:08
  Index 8/8, flood queue length 0
  Next 0x0(0)/0x0(0)
  Last flood scan length is 0, maximum is 0
  Last flood scan time is 0 msec, maximum is 0 msec
  Neighbor Count is 0, Adjacent neighbor count is 0
  Suppress hello for 0 neighbor(s)
Vlan468 is up, line protocol is up
  Internet Address 10.115.40.1/24, Area 0
  Designated Router (ID) 192.168.162.2, Interface address 10.115.40.1
    Hello due in 00:00:05
  Index 27/27, flood queue length 0
  Next 0x0(0)/0x0(0)
You need to check these subnets on other router's ospf database.
In OSPF database you see only subnets that are advertised by neighbor ospf routers.
Please rate helpful posts.
Best regards,
Abzal
Hi Abzal
I understand that now however
I have looked on another router 192.168.162.1 and as can be seen from the out put below this does not show the networks either
       OSPF Router with ID (192.168.162.1) (Process ID 1)
192.168.162.1   192.168.162.1   963         0x800260A7 0xF258   30
192.168.162.2   192.168.162.2   769         0x800261CD 0x9794   43
192.168.162.3   192.168.162.3   857         0x8001EF3D 0xDA3F   58
192.168.162.7   192.168.162.7   67          0x80004C68 0xE961   25
192.168.162.8   192.168.162.8   1616        0x800122D7 0xA938   25
10.89.164.3     192.168.162.3   881         0x800041F5 0x6FDC
10.89.164.131   192.168.162.3   882         0x800041F6 0x6862
10.89.184.3     192.168.162.3   882         0x80000C6B 0x3643
10.115.0.5      192.168.162.2   802         0x800001D2 0x2794
10.115.1.193    192.168.162.1   1004        0x800001DA 0x49EB
10.115.6.2      192.168.162.3   882         0x80000C6B 0x3919
10.115.18.1     192.168.162.2   802         0x80000C6C 0x34D4
10.115.32.2     192.168.162.2   802         0x80000C6C 0x8F6A
10.115.46.3     192.168.162.3   882         0x800041FA 0x40E3
10.115.50.2     192.168.162.3   882         0x80000C6B 0xDC09
10.115.64.129   192.168.162.1   1004        0x800001D2 0x7F83
10.115.64.133   192.168.162.1   1004        0x800001FD 0xFC3
10.115.64.138   192.168.162.3   1389        0x800001D2 0x2DC8
10.115.64.145   192.168.162.1   1004        0x80000200 0x1AA3
10.115.97.2     192.168.162.7   85          0x8000259F 0x86D4
10.115.98.3     192.168.162.7   85          0x800025A4 0x3B09
10.115.104.4    192.168.162.3   883         0x80000C6C 0x1092
10.115.112.8    192.168.162.7   85          0x80001F0A 0xE1FF
10.115.113.2    192.168.162.7   85          0x80004153 0x9E1C
10.115.113.66   192.168.162.7   85          0x80004152 0x1E5D
10.115.113.131  192.168.162.8   1626        0x80001F0B 0x7C26
10.115.113.194  192.168.162.7   85          0x80004152 0x19E1
10.115.114.2    192.168.162.7   85          0x8000259E 0x5139
10.115.114.130  192.168.162.7   86          0x80004152 0x90A9
10.115.115.131  192.168.162.8   1626        0x80001F0B 0xE4FB
10.115.116.2    192.168.162.7   86          0x80004152 0xFDFA
10.115.116.130  192.168.162.7   86          0x80004152 0xF87F
10.115.117.2    192.168.162.7   86          0x80004152 0xF205
10.115.117.130  192.168.162.7   86          0x80004152 0xED89
10.115.118.2    192.168.162.7   86          0x8000259F 0xA124
10.115.118.130  192.168.162.7   86          0x80004151 0xE492
10.115.119.2    192.168.162.7   86          0x8000259F 0x962E
10.115.120.2    192.168.162.7   86          0x80004152 0xD123
10.115.125.2    192.168.162.8   1627        0x80000C72 0xEC97
172.20.1.4      192.168.162.7   87          0x800025A6 0x2415
192.168.76.3    192.168.162.7   87          0x80004152 0xE4CF
192.168.144.2   192.168.162.2   805         0x800001DA 0x585F
192.168.161.3   192.168.162.1   1007        0x800001D2 0x9020
192.168.176.14  192.168.162.3   885         0x80000C6B 0x214F
192.168.177.3   192.168.162.2   805         0x80000C6C 0x7EFC
and on our 3rd router 192.168.162.3 it does not show either
       OSPF Router with ID (192.168.162.3) (Process ID 3)
192.168.162.1   192.168.162.1   1134        0x800260A7 0xF258   30
192.168.162.2   192.168.162.2   932         0x800261CD 0x9794   43
192.168.162.3   192.168.162.3   1011        0x8001EF3D 0xDA3F   58
192.168.162.7   192.168.162.7   214         0x80004C68 0xE961   25
192.168.162.8   192.168.162.8   1754        0x800122D7 0xA938   25
10.89.164.3     192.168.162.3   1011        0x800041F5 0x6FDC
10.89.164.131   192.168.162.3   1011        0x800041F6 0x6862
10.89.184.3     192.168.162.3   1011        0x80000C6B 0x3643
10.115.0.5      192.168.162.2   932         0x800001D2 0x2794
10.115.1.193    192.168.162.1   1134        0x800001DA 0x49EB
10.115.6.2      192.168.162.3   1011        0x80000C6B 0x3919
10.115.18.1     192.168.162.2   932         0x80000C6C 0x34D4
10.115.32.2     192.168.162.2   932         0x80000C6C 0x8F6A
10.115.46.3     192.168.162.3   1011        0x800041FA 0x40E3
10.115.50.2     192.168.162.3   1011        0x80000C6B 0xDC09
10.115.64.129   192.168.162.1   1134        0x800001D2 0x7F83
10.115.64.133   192.168.162.1   1134        0x800001FD 0xFC3
10.115.64.138   192.168.162.3   1517        0x800001D2 0x2DC8
10.115.64.145   192.168.162.1   1134        0x80000200 0x1AA3
10.115.97.2     192.168.162.7   214         0x8000259F 0x86D4
10.115.98.3     192.168.162.7   214         0x800025A4 0x3B09
10.115.104.4    192.168.162.3   1011        0x80000C6C 0x1092
10.115.112.8    192.168.162.7   214         0x80001F0A 0xE1FF
10.115.113.2    192.168.162.7   214         0x80004153 0x9E1C
10.115.113.66   192.168.162.7   214         0x80004152 0x1E5D
10.115.113.131  192.168.162.8   1754        0x80001F0B 0x7C26
10.115.113.194  192.168.162.7   214         0x80004152 0x19E1
10.115.114.2    192.168.162.7   214         0x8000259E 0x5139
10.115.114.130  192.168.162.7   214         0x80004152 0x90A9
10.115.115.131  192.168.162.8   1754        0x80001F0B 0xE4FB
10.115.116.2    192.168.162.7   214         0x80004152 0xFDFA
10.115.116.130  192.168.162.7   214         0x80004152 0xF87F
10.115.117.2    192.168.162.7   214         0x80004152 0xF205
10.115.117.130  192.168.162.7   214         0x80004152 0xED89
10.115.118.2    192.168.162.7   214         0x8000259F 0xA124
10.115.118.130  192.168.162.7   214         0x80004151 0xE492
10.115.119.2    192.168.162.7   214         0x8000259F 0x962E
10.115.120.2    192.168.162.7   214         0x80004152 0xD123
10.115.125.2    192.168.162.8   1754        0x80000C72 0xEC97
172.20.1.4      192.168.162.7   214         0x800025A6 0x2415
192.168.76.3    192.168.162.7   214         0x80004152 0xE4CF
192.168.144.2   192.168.162.2   932         0x800001DA 0x585F
192.168.161.3   192.168.162.1   1135        0x800001D2 0x9020
192.168.176.14  192.168.162.3   1011        0x80000C6B 0x214F
192.168.177.3   192.168.162.2   932         0x80000C6C 0x7EFC
Thanks for all the help
Hi Alex,
The purpose of this LSA type is to describe router’s links (interfaces)  in such a way that other routers in the same area can understand it and  build their SPF trees based on that information.   The Link ID for router LSA would the Router ID itself.
You can see this link informations only by executing "show ip ospf database ", if you try from any router within that area.  If you go to any ABR, u will it as summary LSA
Sudeep
