OSPF functions. Load balancing.
hanwucisco
R1-----R2====R3------R4
The 4 of them are running OSPF in one area. Between R2 and R3, I configured two simple GRE tunnels. I want to user’s traffic from R1 to R4 to use the two tunnels via OSPF load balancing. What is the best way to do that? I mean the traffic always going through the physical link no the tunnels.
Han
6 Accepted Solutions
Edison Ortiz
modify the ospf cost on the GRE tunnel to match the LAN. By default, the cost is calculated based on BW from the interface.
type show ip ospf interface and you will see the OSPF cost for the GRE and physical connection - make sure they match.
Are both tunnels up? Let's see the output from show interfaces on that router.
hanwucisco wrote:
I tried this one though, but I have an issue. I put the physical and two tunnels into OSPF on R2 and R3, but when I show IP ospf neighbor, it only show two links that have neighbor. Only physical link and the tunnel with high IP. Does it need special configuration on OSPF to make it recognize the two tunnels?
thanks,
Han
How are your tunnel destination IP Addresses learnt by the routers? Do make sure that the tunnels do not use OSPF to actually establish the tunnel endpoint reachability as otherwise you will end up in a recursive routing issue especially when you lower the cost of the tunnels to have them preferred over your physical links. This can happen when the tunnel destinations become reachable via the tunnels themselves which eventually breaks the tunnel connectivity and the process repeats unless you manually fix it.
In your case if the GRE tunnel destinations are reachable via connected or static routes then you should not have an issue and OSPF should prefer the tunnels if you lower their cost compared to the physical links. If, however, you are using OSPF in the first place to discover the tunnel destinations then you will run into the issue I mentioned above. By the way what is the motivation to use GRE tunnels here?
Atif
Can you post your OSPF config as well as the output of the 'show ip ospf interface brief' command for both routers?
Atif
Enabling ospf only on tunnel interfaces will do.Tunnel reachability can be done via static routes!!
~bava
Please provide:
-show ip ospf interface tunnel0/1
-show interface tunnel 0/1
-ping 224.0.0.5
-ping 224.0.0.6
-show ip os nei detail
-debug ip ospf adj
-debug ip ospf hello
-show run int tunnel0/1
-ping 10.0.0.3 size (mtu of tunnel intf) df-bit
You could also configure:
router ospf XX
log-adjacency-changes detail
and check the log for OSPF messages.
Luc
13 Replies 13
Edison Ortiz
thanks,
Han
Yes, tunnels are both up and pingable.
R3(config-router)#do sh ip int bri | e una
Interface                  IP-Address      OK? Method Status                Protocol
Serial1/0                  1X.1.23.3        YES manual up                    up
Serial1/1                  1X.1.34.3        YES manual up                    up
Tunnel0                    10.0.0.3        YES manual up                    up
Tunnel1                    10.0.1.3        YES manual up                    up
R3(config-router)#do ping 10.0.0.2
Sending 5, 100-byte ICMP Echos to 10.0.0.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 32/57/92 ms
R3(config-router)#do ping 10.0.1.2
Sending 5, 100-byte ICMP Echos to 10.0.1.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 40/67/104 ms
R3(config-router)#
But only one tunnel has cdp nei to R2.
R3(config-router)#do sh ip os nei
Neighbor ID     Pri   State           Dead Time   Address         Interface
1X.4.4.4           0   FULL/  -        00:00:38    1.1.34.4        Serial1/1
10.0.1.2          0   FULL/  -        00:00:30    10.0.1.2        Tunnel1
R3(config-router)#
thanks,
Han
Atif
I created the tunnel first and pinged. Then I put OSPF. So there shouldnt have that problem.
thanks,
Atif
~bava
R3#sh run | b r o
router ospf 1
network 1.1.34.3 0.0.0.0 area 0
network 10.0.0.3 0.0.0.0 area 0
network 10.0.1.3 0.0.0.0 area 0
R3#sh ip os interface brief
Interface    PID   Area            IP Address/Mask    Cost  State Nbrs F/C
Se1/1        1     0               1.1.34.3/24        64    P2P   1/1
Tu0          1     0               10.0.0.3/24        11111 P2P   0/0
Tu1          1     0               10.0.1.3/24        11111 P2P   1/1
R2#sh ip os
*Mar  1 00:31:26.219: %SYS-5-CONFIG_I: Configured from console by console
R2#sh ip os int bri
Se1/0        1     0               1.1.12.2/24        64    P2P   1/1
Tu0          1     0               10.0.0.2/24        11111 P2P   0/0
Tu1          1     0               10.0.1.2/24        11111 P2P   1/1
R2#
router ospf 1
network 1.1.12.2 0.0.0.0 area 0
network 10.0.0.2 0.0.0.0 area 0
network 10.0.1.2 0.0.0.0 area 0
Please provide:
-ping 224.0.0.5
-ping 224.0.0.6
-debug ip ospf adj
router ospf XX
Luc
Thank you all. I solved the problem in a different appoach.
testing where I land
Cheers, Dan
esomarriba
Level 5
Level 5
What was your solution?
