03-11-2013 04:30 PM - edited 03-04-2019 07:15 PM
Hi guys, please help me..
I'm trying to development the topology about INE course.. and i have some problems with ping routers inter-area..
Have 2 ABR, conecting each other by frame-relay(ASBR router5), i can see the router neighbour but not ping.. follow the topology by GNS3..
Problem..
Router 2 not can ping router 4(10.1.4.4) or router 6(10.1.6.6)
Router 3 not can ping router 4 or router 6..
R2#sh ip route
10.0.0.0/8 is variably subnetted, 12 subnets, 2 masks
O IA 10.1.4.4/32 [110/65] via 10.1.245.4, 00:00:57, Serial1/0.1
R2#sh ip route 10.1.4.4
Routing entry for 10.1.4.4/32
Known via "ospf 1", distance 110, metric 65, type inter area
Last update from 10.1.245.4 on Serial1/0.1, 00:04:40 ago
Routing Descriptor Blocks:
* 10.1.245.4, from 10.1.4.4, 00:04:40 ago, via Serial1/0.1
Route metric is 65, traffic share count is 1
thanks..
Solved! Go to Solution.
03-12-2013 03:03 AM
Hello Josue,
You do not have complete mapping on R2 and R4. Add theese mappings and it will work ->
R2(config)#int Serial1/0.1 multipoint
R2(config-subif)#frame-relay map ip 10.1.245.4 205 broadcast
R4(config)#interface Serial1/0.1 multipoint
R4(config-subif)#frame-relay map ip 10.1.245.2 405 broadcast
R2#ping 10.1.4.4
Success rate is 100 percent (5/5), round-trip min/avg/max = 52/79/120 ms
R2#ping 10.1.6.6
Success rate is 100 percent (5/5), round-trip min/avg/max = 88/108/168 ms
R3#ping 10.1.4.4
Success rate is 100 percent (5/5), round-trip min/avg/max = 92/97/104 ms
R3#ping 10.1.6.6
Success rate is 100 percent (5/5), round-trip min/avg/max = 96/108/124 ms
Best Regards
Please rate all helpful posts and close solved questions
03-12-2013 03:03 AM
Hello Josue,
R2#ping 10.1.4.4
R2#ping 10.1.6.6
R3#ping 10.1.4.4
R3#ping 10.1.6.6
Best Regards
03-12-2013 10:17 AM
Thanks Blau..
i realy forget.. thank you so much..
by
