OSPF ISSUE
tarunavakonar
4w6d: OSPF: Rcv pkt from 10.205.32.2, Vlan1, area 0.0.0.0 : src not on the same
network
Plz find the error message
suggest me
5 Replies 5
Danilo Dy
Can you post the config?
Just a long shot, you seems to have an adjacency problem. The interfaces that communicates to form a OSPF adjacency between the two routers needs to be in the same IP subnet/network.
This mean that the local router VLAN1 interface ip addressress is not in the same IP subnet/network where the remote router interface configured with 10.205.32.2
For example: If the remote router interface use to form adjacency with the local router is configured with IP subnet/network of 10.205.32.2/30 your local router VLAN1 interface should be configured with IP subnet/network of 10.205.32.1/30
router int config ot L3 switch & router ospf config
interface FastEthernet0/0
ip address 10.205.31.1 255.255.255.0
no ip redirects
ip route-cache policy
ip route-cache flow
duplex auto
speed auto
end
router ospf 1
router-id 10.220.31.1
log-adjacency-changes
redistribute connected metric-type 1 subnets
redistribute static metric-type 1 subnets
network 10.0.0.0 0.255.255.255 area 0
L3 VLAN and ospf config
interface Vlan1
ip address 10.205.31.2 255.255.255.0
ip helper-address 10.205.35.250
no ip redirects
interface Vlan2
ip address 10.205.32.2 255.255.255.0
no ip redirects
interface Vlan3
ip address 10.205.35.2 255.255.255.0
no ip redirects
router ospf 1
router-id 10.220.31.2
redistribute static metric 150 metric-type 1 subnets
plz suggest me
Tarunava
There appears to be a device in vlan 1 with IP address 10.205.32.2 which is also the address of your vlan 2 interface. Is it possible that the cables got swapped and that the router is actually connected to vlan 2 instead of vlan 1?
Perhaps posting the output of show cdp neighbor would be helpful.
Rick
Rick
every thing is ok
Tarunava
We are glad that every thing is ok. It would help the forum if you would explain for us what was the problem and how did you solve the problem. It makes the forum more useful if we see description of a problem to also be able to know the definition of the problem and the steps to resolve the problem.
Rick
Rick
