OSPF issue
tanmoymm91
I have changed the MTU on R2 interface (Gi0/0/0) from default (1500) to 1300 but its neighborship still showing in Full state it should be EXSTART state .
what happened wrong , kindly share your views .
i am sharing all related configs on both routers
R2#show run | s ospf
router ospf 10
router-id 1.1.1.1
log-adjacency-changes
network 10.1.1.0 0.0.0.255 area 0
R2#
R2#show int gi0/0/0
GigabitEthernet0/0/0 is up, line protocol is up (connected)
Hardware is Lance, address is 0030.a3c4.aa01 (bia 0030.a3c4.aa01)
Internet address is 10.1.1.2/24
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Full-duplex, 100Mb/s, media type is RJ45
ARP type: ARPA, ARP Timeout 04:00:00,
Last input 00:00:08, output 00:00:05, output hang never
Input queue: 0/75/0 (size/max/drops); Total output drops: 0
Queueing strategy: fifo
Output queue :0/40 (size/max)
5 minute input rate 61 bits/sec, 0 packets/sec
5 minute output rate 59 bits/sec, 0 packets/sec
215 packets input, 14056 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
196 packets output, 12764 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 lost carrier, 0 no carrier
R1#show run | s ospf
router ospf 10
router-id 2.2.2.2
R1#show int gi0/0/0
Hardware is Lance, address is 0000.0cc5.5c01 (bia 0000.0cc5.5c01)
Internet address is 10.1.1.1/24
MTU 1300 bytes, BW 1000000 Kbit, DLY 10 usec,
5 minute output rate 60 bits/sec, 0 packets/sec
253 packets input, 16804 bytes, 0 no buffer
236 packets output, 15448 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
R2#show ip ospf nei
Neighbor ID Pri State Dead Time Address Interface
2.2.2.2 1 FULL/DR 00:00:32 10.1.1.1 GigabitEthernet0/0/0
R1#show ip osp nei
1.1.1.1 1 FULL/BDR 00:00:34 10.1.1.2 GigabitEthernet0/0/0
6 Replies 6
M02@rt37
Hello @tanmoymm91,
OSPF adjacencies can remain stable even when there are changes to underlying parameters like MTU. In such cases, the routers continue using the existing adjacency without renegotiating. To ensure that the MTU change is recognized, you can try clearing the OSPF adjacency on both routers using the "clear ip ospf process" command.
Best regards
I think the issue with the Packet tracer tool , although i am using the latest one (8.2.1) .
but yes , the concept wise MTU must be same on both side otherwise it will stuck in exstart state
the OSPF not detect MTU change until change UPDATE.
so either you wait until the prefix aging or clear OPSF process
but yes , the concept wise it should be in exstart state .
I will check using GNS3
change the MTU of R1 interface, the OSPF still UP
later I clear ospf process and debug show you in which steps the OSPF stop EXSTART and reason of that the MTU mismatch
